TE37 pricing?
Old May 5, 2003 | 12:11 AM
syf0n's Avatar
syf0n
Default TE37 pricing?
I am looking to score a set of TE-37 rims. Anyone have valid pricing?
Front: 18 x 9.5
Rear: 18 x 11 (275mm...is 11 right? Or is it 10.5??)
I have looked around and found them for $400 but have no idea what to think of that price as high or low.
thanks in advance to anyone with info!
Old May 5, 2003 | 03:41 AM
Alev's Avatar
Alev
Where did you find them for $400?
Old May 5, 2003 | 03:50 AM
Pedal Pusher's Avatar
Pedal Pusher
Please.....where did you find them for $400?
Old May 5, 2003 | 10:15 AM
syf0n's Avatar
syf0n
A site called oVerboost or similar? I take it by the way you guys said that that 400 is low =\
Also, any ideas about the sizing?
Old May 5, 2003 | 10:57 AM
Pedal Pusher
Default Wheel Size
IMO, you are asking for some steering and suspension problems with wheels that wide. There is a lot of information on Tirerack.com regarding wheel width and size. Do some home work and see what you can learn.
Old May 5, 2003 | 12:37 PM
ares's Avatar
ares
Veteran
what do you mean by 275mm? are you talking about width of tread? if so 275tread goes with 9.5" rims... otherwise Ive only heard of 10.5" no 11 that I know of.
best price Ive seen was approx 500$ each and that was for 8.5 and 9.5 combo.
Old May 5, 2003 | 12:40 PM
ares's Avatar
ares
Veteran
just jumped over to overboost.com
they have 18x8.5, 9, 9.5; dont show that they sell anything bigger than 9.5, tho I know they are made.
they are getting 570-580 each depending on width
Old May 5, 2003 | 03:13 PM
syf0n's Avatar
syf0n
I know what tires I am getting. I like wide tires. I know that handling issues won't be that big a deal in reality, but I am aware that they will exist compared to smaller tires.
I am going to get a set of Goodyear Eagle F1 tires.
Front: 245/40
Rear: 275/40
What size rims do I need to get then? I don't understand what the difference would really be, it is confusing me a lot...what is the fitting difference going to be?
I just want these rims and these tires, please help! I don't need a lecture on how wide tires will affect handling as I know this already.
Sizing is my concern, I just don't understand what size rims I need for the size tires I want.
Old May 5, 2003 | 03:22 PM
Traffic's Avatar
Traffic
Front: 245/40
Rear: 275/40
Get 18x8.5 front and 18x9.5 rear. The tires should then fit perfectly.
Old May 5, 2003 | 03:33 PM
syf0n's Avatar
syf0n
thanks!
Old May 5, 2003 | 03:50 PM
failsafe's Avatar
failsafe
....for your health
thanks!
Syphon- I'm running 8.5F and 9.5R (19"), you should be OK with the tires you listed.
Old May 5, 2003 | 04:02 PM
ares's Avatar
ares
Veteran
thats what I have, I even have the eagle F1 on the rear. works great.
Old May 5, 2003 | 05:46 PM
MATIX's Avatar
MATIX
go for 9.5" front, 10.5" rear...that setup looks sweet, and the tires you have will fit....only thing is you'll have to roll the fender in the rear
Old May 5, 2003 | 05:58 PM
syf0n's Avatar
syf0n
on a scale of 1 to 10, how much better are the F1's than stock tires?
Old May 5, 2003 | 05:59 PM
syf0n's Avatar
syf0n
what do you mean roll the fender??? please explain...
will the car handle 9.5" without "rolling"? why did he say I'd be able to use 9.5" if you're saying 10.5? what is the difference?
Old May 5, 2003 | 06:13 PM
MATIX's Avatar
MATIX
you can use 9.5 inches wide in the back, or 10.5 inches in the back, the 10.5's look better though IMO because you get a lip with bent spokes, rolling the fender means that the 1/2" piece of metal that extends horizontally on the inside of your fender will either need to be "rolled" up (as in bent), or cut down a little bit to fit the 10.5 inch rim in the wheel well so it doesnt rub.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
