Squeaking Rear
Old Jul 1, 2007 | 02:14 AM
GA_VQ's Avatar
GA_VQ
Default Squeaking Rear
I have an '05 6MT with about 50K miles. There is a squeaking sound coming from what I think is the rear suspension. Either I can only hear it at low, parking lot speeds, or thats the only time it exists. Any ideas?
Old Jul 1, 2007 | 06:41 AM
LG_z33's Avatar
LG_z33
Do you have stock suspension?
Old Jul 1, 2007 | 06:43 AM
GA_VQ's Avatar
GA_VQ
Yup
Old Jul 12, 2007 | 05:12 PM
GA_VQ's Avatar
GA_VQ
I had someone else listen to it today. They descibed it as a clicking/squeaking type noise. It happens when I speed up and slow down at parking lot speeds. It's really getting under my skin!
Old Jul 15, 2007 | 07:40 AM
bigphil's Avatar
bigphil
need to grease here. Bottom joint on the rear swaybar.
Old Aug 16, 2007 | 04:32 AM
gto88's Avatar
gto88
Hi,
I have same noise under same situation (parking lot speed), I went to dealership
3 times for the same problem.
They have done rear axle tsb and replaced suspension without any luck.
The noise seems getting worse, I can hear it all the time when in low speed and especially when I turn left.
Any one try this grease fix?
I will try it, and can you tell me what do you use to grease it.
Thanks.
Old Aug 16, 2007 | 05:15 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I have the same noise.
I plan to change out the entire bushings and we'll see if that fixes the noise. I'll also try to grease those areas.
I drift, so I figured my bushings are done... I have 30K BTW.
Old Aug 16, 2007 | 08:52 AM
jinsei888's Avatar
jinsei888
Originally Posted by gto88
Hi,
Thanks.
+1 i'm also curious about this! what kinda grease?
Old Aug 16, 2007 | 10:01 AM
GA_VQ's Avatar
GA_VQ
I tried WD-40 cause it looks like the straw in the picture but it didn't work. Maybe dissassemble, grease, and reassemble... what kind of grease?
Old Aug 16, 2007 | 12:58 PM
nator's z's Avatar
nator's z
Ahhhhh, I got the same noise as well. Will try greasing it. Started as what sounded like a squeak and has gotton progressively louder. I've got 3600 miles on my '06. Lowered on Eibach's.
Old Aug 16, 2007 | 01:08 PM
BhashaZ's Avatar
BhashaZ
Yes what kind of grease? I also have a creaking/squeeky rear that is getting really annoying!
Old Aug 16, 2007 | 05:06 PM
GA_VQ's Avatar
GA_VQ
Has no one figured out how to fix this problem?
Old Aug 17, 2007 | 05:49 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
FIXED!!!!
BigPhil is right. It's those sway bar link joints that make horrible creaking noises!! I went to the shop last night, and my mechanic squarted oil into those joints with a needle syringe and the noise disappeared instantly! He used the needle syringe, because it is crucial to put the oil deep inside those joints. Good luck!
Old Aug 17, 2007 | 05:52 PM
GA_VQ's Avatar
GA_VQ
What kind of oil?
Old Aug 17, 2007 | 05:59 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Sorry I didn't check which grease/oil he used. I was originally going to use the "****" grease.. one of those thick heavy greases.... but my mechanic went and got some yellowish trasparent and apparently not too tick enough grease to put in the syringe.. It just might be a motor oil... You know, it's just a simple joint.. I bet you can pretty much use any type of automotive grease. What's important is you must apply the grease deep inside the joint...
Old Aug 17, 2007 | 06:00 PM
GA_VQ's Avatar
GA_VQ
Okay. I think I'll try to disassemble them and regrease.
Old Sep 10, 2007 | 04:39 AM
chamois's Avatar
chamois
when i install after market sway bars should i grease/ oil the bushings or anything? and also i would like to know what kind of grease you guys used ?
Old Sep 10, 2007 | 09:38 AM
gto88's Avatar
gto88
Originally Posted by leeboyNY
FIXED!!!!
Hi Leeboy,
Can you give the shop a call to find out the grease.
You are the only one in this thread who had the latest experience that works.
Help us here.
Thanks,
Old Sep 10, 2007 | 09:45 AM
phreaktor's Avatar
phreaktor
Design Engineer
You need to put some elbow grease on the LSD transmogrifier spline. After about 25,000 miles, the spline becomes engorged with road tar and maple syrup. Listerine works wonders as well. Hope this helps. Good luck.
Old Sep 13, 2007 | 12:24 PM
GA_VQ's Avatar
GA_VQ
Thanks for the help, jackass.
