TPS Compatibility
Old Jul 2, 2007 | 10:24 AM
bwright's Avatar
bwright
Default TPS Compatibility
I have searched the threads and not found an answer to this question. Since the '07 has changed the way the TPS work, will the '03 - '06 sensors work in an '07. Any help would be appreciated.
Old Jul 2, 2007 | 12:40 PM
ssc's Avatar
ssc
how do the 07 tps work?
Old Jul 2, 2007 | 01:06 PM
bwright's Avatar
bwright
'03 thru '06 give you a tire pressure readout, '07 just inform you of a low pressure situation.
Old Jul 2, 2007 | 01:57 PM
DavesZ#3's Avatar
DavesZ#3
The sensors are still the same. The part that changed is the computer end that controls the display.
Old Jul 2, 2007 | 02:12 PM
bwright's Avatar
bwright
According to Jason@riverside, the '07 sensors have a different part number, sure would be helpful if someone could tell me if the old ones would work or not. Seems like someone here should have tried to do this by now
Old Jul 4, 2007 | 05:33 PM
bwright's Avatar
bwright
bump....still need an answer on this
Old Jul 4, 2007 | 05:58 PM
DavesZ#3's Avatar
DavesZ#3
Different part # doesn't mean that it's a totally different sensor or it's incompatible. Could be a new version of the same thing. Somebody (like Jason) will need to verify if they are compatible or not.
Old Sep 23, 2007 | 01:36 PM
07BlackG35Stud's Avatar
07BlackG35Stud
Here' some input: I have a 2007 G35 coupe and I purchased a set of pre-07 sensors for my aftermarket wheels (didn't wanna get the stock ones off the stock wheels). The dealer is unable to program the older year sensors on my 2007 coupe, which leads me to think that they work differently as well. It may not be the same for 350z's, but since they share so many parts in common, you may run into the same issue. I'm presently lookign for a set of used 2007 sensors...
SharX59
Sep 27, 2015 09:23 AM
bryanlam199
Sep 24, 2015 04:04 PM
azrael
Nov 28, 2003 12:22 PM
