Shakey at 80mph
Old Jul 5, 2007 | 12:54 PM
psytropic's Avatar
psytropic
Default Shakey at 80mph
Was on the freeway today and got up to 80 when I noticed a more that slight shake, I can feel it in the steering wheel and feel the car also.
Checked tire pressure at 27psi on both front tires. Think it could be that or maybe something more serious like bad tires or alignment?
Old Jul 5, 2007 | 12:56 PM
350Z84's Avatar
350Z84
Your wheels might need balancing. How long have you been running the current wheels and tires?
Old Jul 5, 2007 | 01:01 PM
FastZ33's Avatar
FastZ33
check ur end links, sways, shock bolts
Old Jul 5, 2007 | 01:07 PM
psytropic's Avatar
psytropic
bout 8700 miles on the front tires, stock sized Hankook Ventus HRII's
Are end links sorta like tie rods?? lol I know it's a stupid question but this is my first new car pre 1976
Old Jul 5, 2007 | 01:30 PM
a. loose front lug nuts
b. front end out of alignment
c. bent front rims
d. a cracked frame
e. worn wheel bearings
d. bad steering stabilizer
Old Jul 5, 2007 | 02:07 PM
350Zenophile's Avatar
350Zenophile
Most likely wheels need balancing.
And put some air in those tires!!! Should be 35psi
Old Aug 28, 2007 | 10:40 AM
psytropic's Avatar
psytropic
ok I know it's been awhile since I posted. I did my front brakes today and took off the rims and did a thorough cleaning. Well guess what, apparently Discount Tire uses little stick on weights for tire balance. And they all fell off the passenger side rim.
JasonZ
Jun 28, 2009 06:16 PM
VN_350z
Aug 17, 2006 03:40 AM
The Mike
Jun 25, 2006 06:47 PM
