295 on a 9.5 inch wheel
Old Jul 16, 2007 | 07:16 AM
Drift_corners's Avatar
Drift_corners
Default 295 on a 9.5 inch wheel
On the bridgestone website it says that for the 295/30/18 RE050A Pole position the aproved wheel size is 10-11.5 i have a 9.5 inch wide wheel. will this be ok, it is a track car. Performance is key
Old Jul 16, 2007 | 07:19 AM
bacalhau16's Avatar
bacalhau16
If it is a track car, then it is important that you properly match your tires and rim size. You should stay within the guidelines for that rim. Go with a 9" rim, if the 9.5" rim suggests a wider tire.
Old Jul 16, 2007 | 11:16 AM
DustinZ33's Avatar
DustinZ33
What kind of tracking are you doing with this setup? I would go with a 275 or 285.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
