Fitting longer rear wheel studs?
Old Jul 16, 2007 | 03:17 PM
Dakota_za's Avatar
Dakota_za
Default Fitting longer rear wheel studs?
I just got a set of Isotta 16mm rear wheel spacers with extended studs for my '04 350z
The problem that I found is that after removing the caliper & disk & handbrake shoes to expose the hub, there just isn't enough space between the hub & the dust cover to get longer studs behind the hub to push them through. I've tried rotating the hub to get to a point where the gap is largest, but its still not enough.
Do I have to remove the entire hub assembly? It doesnt look to easy to loosen those 4 bolts holding the hub assembly to the suspension. Do I pull the front of the hub out of the bearing?
Any links or advice appreciated.
Old Dec 14, 2007 | 02:47 PM
OH6 G35's Avatar
OH6 G35
Boy, this is a really "old" thread but...
I'm looking for the answers to this also.
Anyone ??
What type of puller did you use to remove the hub?
Old Dec 15, 2007 | 12:19 PM
OH6 G35's Avatar
OH6 G35
https://my350z.com/forum/wheels-and-tires/263033-nismo-60mm-extended-wheel-studs.html
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
RWDBajan
Sep 17, 2015 04:52 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
