tire question
Old Jul 23, 2007 | 08:13 AM
ofl0926's Avatar
ofl0926
Default tire question
hey whats up, i have a question. i was on discount tire direct website and put in my car info and the recommendation they give for 20s in the rear is a 275/35/20. my question is, is that correct. right now i am running a 275/30/20 and was thinking about running a 285/30/20. any thoughts???
Old Jul 24, 2007 | 02:23 PM
VIZAGE's Avatar
VIZAGE
Well it's just a recommendation. I see you have an 10'' wide wheel. I'd go with an 285 also. But being 20's with 285's and your lowered. Make sure you don't have any rubbing issues first. This way you can return them before it's to late.
Old Jul 24, 2007 | 03:00 PM
wayneside's Avatar
wayneside
you can do it...its not much of a difference...
Old Jul 24, 2007 | 03:37 PM
OffsetZ33's Avatar
OffsetZ33
My preference would be a 285/25/19 personally - there are some members here who run 20s with that size and I think it fits better. For reference I am running 265/30/19 and 275/30/19 front and rear, but am pretty low as well. The shorter sidewall doesnt really look good if the car is not low enough IMO though.
edit:
-Here is a sweet setup if you have the right width to pull off the tire sizing:
https://my350z.com/forum/wheels-and-tires/285423-cor-concord-forged-wheels-no-volks-inside.html
Old Jul 24, 2007 | 03:54 PM
ofl0926's Avatar
ofl0926
edit:
https://my350z.com/forum/showthread.php?t=285423
that link you showed me. with a width of 10, do you think it will work. not too sure on the offset but i am lowered on tanabe springs. what do you think
Old Jul 24, 2007 | 04:48 PM
The front tires are 0.5 mm taller than the rear. You realise this correct?
Edit: No matter. I just noticed that you have the Base.
Old Jul 24, 2007 | 05:05 PM
ofl0926's Avatar
ofl0926
even if that rear sat higher than the front, how would this afffect me
Old Jul 24, 2007 | 05:27 PM
The stock 350Z is about 18 mm taller in the rear. Altering the difference effects handling. Since you are lowered with 20-inch wheels, I doubt if it matters.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Mattg350z
Oct 2, 2015 06:51 AM
