Best size without rolling the fender?
Old Aug 2, 2007 | 05:45 PM
Yokohamaz's Avatar
Yokohamaz
Default Best size without rolling the fender?
I just got my 2007 Z and I plan on getting a set of 19' Volk GTF's. Can someone make a recommendation in offsets, etc. so I can get the aggressive stance without having to roll the fenders or have any rubbing problems? Tire size suggestions would be appreciated too
Yz
Old Aug 2, 2007 | 06:53 PM
Sick Z's Avatar
Sick Z
Go as aggressive as you can and roll the fenders, there's a diy thats really easy to do in the forums. Otherwise you are going to settle for higher offsets and regret it down the line
I have +17 +18 GTS wheels on my 07, did the DIY fender rolling looks sick!!
Old Aug 2, 2007 | 07:02 PM
DavesZ#3's Avatar
DavesZ#3
I'm running Volk LE37T's in 19" with 9½" front, 10½" rear, +22 offset on both front and rear. For tires, I'm using Michelin PS2s - 255/35 in front, 285/35 in rear. No rubbing problems at all.
Pics can be seen in this thread...
https://my350z.com/forum/media-share/185317-db-with-new-volk-le37t.html
Old Aug 2, 2007 | 07:19 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Dave can pull off 285s because of his +22 offset. You go any lower you're going to have to roll.
Old Aug 2, 2007 | 08:09 PM
Yokohamaz's Avatar
Yokohamaz
Dave, is your Z at the stock height? Looks good.
Yz
Old Aug 3, 2007 | 12:56 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Mild fitment for the GTF. will be 19x9.5 +17 19x10.5 +24. You will not need any fender modifications with this fitment. If you want to go aggressive and roll, you can go +15 in the rear. +15 and +24 will give the same wheel depth but the +15 will stick out more giving it a much more aggressive look....
19x10.5 +24 on 285/35/19
19x10.5 +15 on 275/35/19
Old Aug 3, 2007 | 01:01 PM
redlude97's Avatar
redlude97
10.5+22 rubs with 285/35/19 BFG KDW2's, Davboy had them and it rubbed, he had to go down to 275/35/19 on his Time attacks
Old Aug 3, 2007 | 01:31 PM
DavesZ#3's Avatar
DavesZ#3
Yz
Yes. Thanks!
Old Aug 4, 2007 | 02:57 PM
atar350's Avatar
atar350
285/35 bfg's ftw! I had a little rub, but a rubber mallet took care of that.
Old Aug 4, 2007 | 03:43 PM
wayneside's Avatar
wayneside
call Andy @ Performance...he will be able to get you squared away.
Obadabot
Jun 18, 2023 11:31 PM
