Tire sizing
Old Aug 13, 2007 | 08:20 PM
Mr_Kebo's Avatar
Mr_Kebo
Default Tire sizing
I have decided on TOYO Proxes T1R. My dillema now is 245/275 or 255/275. what will be the advantage and disadvantage to each. i want to keep the Vdc happy. I done some searcing and didnt really get a def anwser just alot of back and forth.
Old Aug 13, 2007 | 08:37 PM
What is the front tire size?
The rear?
Old Aug 13, 2007 | 08:45 PM
Mr_Kebo's Avatar
Mr_Kebo
either 245-40-18f/275-40-18r or 255-40-18f/275-40-18r. I dont autoX my car just daily driving and some trip the drag strip.
Old Aug 13, 2007 | 10:35 PM
terrasmak's Avatar
255 front are actually a real even setup , your going up 30mm front and back , instead or changing the stagger more.
Old Aug 18, 2007 | 12:36 PM
Mr_Kebo's Avatar
Mr_Kebo
any other words of advice on the sizing. my wheels are 8.5 front and 9.5 rears
Old Aug 18, 2007 | 12:48 PM
UHATEIT's Avatar
UHATEIT
you definately don't need 255 on the front, you'll bubble over a bit, stick with 245 the best for the front. 275 on the rear will be perfect
Old Aug 18, 2007 | 02:39 PM
Z1NONLY's Avatar
Z1NONLY
I run 255/40-17F and 275/40 17R for autocross and DD.( I tried 245/45 17's up front but it pushed a little) I'm in a base so I don't have to worry about VDC. I have always heard that the VDC wants the back tires to be a little taller than the front, so I don't think this setup would cause any trouble.
Try this site to see how far off your tires would be from stock.
http://www.miata.net/garage/tirecalcold.html
I just tried the numbers and it looks like the 255/40 18F and the 275/40 18R should work.
Old Aug 21, 2007 | 01:26 PM
Mr_Kebo's Avatar
Mr_Kebo
well i am goin with the 255/40 and 275/40 setup. My buddy over in iraq bought me my front tires for my birthday and he got the 255/40. If Vdc dosent like it then i will just turn it off . Any other objections really to this sizing. I dont want to mount the fronts and have problems.
Old Aug 22, 2007 | 10:45 AM
edvy's Avatar
edvy
better fit w/ 245/40, 275/40
http://www.1010tires.com/TireSizeCalculator.asp
Old Aug 22, 2007 | 10:57 AM
redlude97's Avatar
redlude97
but you are increasing your wheel width up front only 1/2" while the rear is going up 1-1.5" depending on your stock setup
Old Aug 22, 2007 | 01:35 PM
Mr_Kebo's Avatar
Mr_Kebo
well the tires that i am running now on these wheels are a 225-40-18f and 265-40-18 rear.Its and enthusiast so whatever the stock sizes were for it.
kyin
Oct 15, 2015 05:54 AM
