sidewall cracked??
Old Aug 19, 2007 | 10:33 AM
SponGer's Avatar
SponGer
Default sidewall cracked??
Was washing my other car and noticed the right front sidewall had two cracks.
I've never had this happen before. The tires are Nitto NT555s - 235/35/19.
Any ideas why this happened? Is it safe?
Old Aug 19, 2007 | 10:34 AM
Nexx's Avatar
Nexx
do you use armor all on your sidewalls?
Old Aug 19, 2007 | 11:36 AM
SponGer's Avatar
SponGer
I'm not a fan of Armor All -- won't use it. I only use Meguiar's or Tire Black on a weekly basis.
Old Aug 19, 2007 | 11:55 AM
This thread needs some photos.
Old Aug 19, 2007 | 11:59 AM
SponGer's Avatar
SponGer
^^will try and post them later. Until then, one is a hairline crack about 3" long.
Old Aug 19, 2007 | 01:35 PM
VENOMSZ's Avatar
VENOMSZ
Not good at all.
Old Aug 20, 2007 | 06:58 AM
Q45tech's Avatar
Q45tech
How old are tires [DOT date of manufacture code on sidewall]?
Some tires spend more than half their useable life in warehouses, on boats, and then back in wholesaler and retailers .
Old Aug 20, 2007 | 09:49 AM
HondaKiller's Avatar
HondaKiller
Nitto tires are garbage, so it doesn't suprise me..... Once you start using Armor All these are some of the reasons why you can't stop using it. Same thing with your dashboard overtime, the heat and cold will expand and contract the rubber. If proper lubrication (armor all) isn't applied during this process cracks can form. Just watch out for bubbles starting to form close to or on top of the crack. if this starts to happen you will need a replacement tire, preferrably not Nitto. (good dry traction tire, but poor quality design)
Old Aug 20, 2007 | 09:58 AM
Ztalker's Avatar
Ztalker
those tire dressings probably ruined your tire prematurely.
Old Aug 20, 2007 | 11:40 AM
boostintt's Avatar
boostintt
my friend rode with something similar for a few k miles... crazy ***
Old Aug 20, 2007 | 08:44 PM
SponGer's Avatar
SponGer
Thanks for the responses. Here's the pic, but you can barely see it. The tires have been on the car for about 15k ; I bought them new with the wheels about two years ago. I thought it was only a myth that dressing caused rubber to crack. Anyway, isn't the crack considered a manufacturer's defect?
Old Aug 20, 2007 | 11:17 PM
Difficult to tell from the photo, but the defect may be superficial. Plenty of road debris that will have similar results.
Keep an eye on the crack. See if it get larger.
Keep your speed below 100 MPH.
Old Aug 21, 2007 | 10:17 AM
Triple8Sol's Avatar
Triple8Sol
It could have also happened due to mounting/dismounting the tire, or driving on it while under-inflated. Time to replace it. Don't risk it...
Old Aug 24, 2007 | 01:23 PM
SponGer's Avatar
SponGer
Went to Discount Tire this morning and had the manager check it out. He said it was a cosmetic crack and nothing to worry about. The tires were manufactured in 03 (bought them in 11/03) and have almost 30,000 miles on them. Indicated tires tend to crack with age. He was surprised I still had decent tread. I guess I'll swap them out when they hit the wear bar.
norrix420
350Z Roadster
May 23, 2022 05:11 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Twenty4
Jan 17, 2016 01:20 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
