TPS accuracy?
Old Sep 6, 2007 | 06:24 AM
jjulich's Avatar
jjulich
Default TPS accuracy?
I was just wondering if anyone has seen how accurate the Tire Pressure Sensor is. I have measured my tires at 35 PSI with a handheld meter and the TPS is saying its 37 PSI. All when the tires are cold. Which one can I believe??
Old Sep 6, 2007 | 08:25 AM
DavesZ#3's Avatar
DavesZ#3
±1psi is what they are rated.
It depends on what quality your handheld meter is. I have a high end dial gauge and when I set mine to 35, they show as 35 in the TPMS display.
Old Sep 6, 2007 | 11:21 AM
n1sm0r's Avatar
n1sm0r
They're more accurate than cheap tire pressure meters
Old Sep 6, 2007 | 01:20 PM
The Brickyard Rat's Avatar
The Brickyard Rat
My TPS seems to give same reading as good hand gauge. But with only 2 PSI different, it ain't a big deal.
Old Sep 8, 2007 | 03:56 PM
trains1937's Avatar
trains1937
I find the readings accurate to within one or two psi when compared to both a digital and mechanical gauge. I try to check tire pressure every few weeks and rely more on the digital gauge since I've read they tend to be the most accurate.
Bassmaster
Feb 25, 2007 06:31 AM
Strife350z
Mar 18, 2005 11:48 AM
LeMansZCa
Mar 24, 2004 01:41 AM
N74DV
Feb 3, 2004 11:18 AM
