1.5" drop
Old May 19, 2003 | 03:10 PM
toykilla's Avatar
toykilla
Default 1.5" drop
will 19's rub if i go this low or should i stick with 18's ??
also what tire diameter would you recommend for each?
Old May 19, 2003 | 03:19 PM
DrDrilZ's Avatar
DrDrilZ
it all depends on the width and offset of your wheels.
Old May 19, 2003 | 04:49 PM
toykilla's Avatar
toykilla
dont have aftermarket wheels yet.. that is why i need some suggestions
Old May 19, 2003 | 09:18 PM
failsafe's Avatar
failsafe
....for your health
toykilla- I'm running 19" x 9.5" on 275's (22mm offset) with about 1.5" drop in rear- no rolled fenders, no rub
John350 is running (if I remember his setup correctly) 19" x 10.5" on 275's (12mm offset) and is dropped a about 2.0" in rear- he had to roll his fenders.
Old May 19, 2003 | 09:36 PM
EnthusiastZ's Avatar
EnthusiastZ
Good info here:
https://my350z.com/forum/showthread....threadid=25905
Old May 19, 2003 | 09:45 PM
N74DV's Avatar
N74DV
i have 19x9.5 in the rear with 285/35/19's. Dropped about 1.2" with an Eibach drop.
my offset is 35mm but I am running 7mm spacers so really it's 28mm. I still have about .15" of room between tire and fender... no rolling needed.
a 9.5" wide rim at about a 28-35mm ought to work just fine. (in the rear) In the front you have more room to play...
apex locator
Jul 23, 2021 02:27 AM
3vilbunny
Jul 18, 2017 05:10 PM
