Hub Centric ring question
Old Sep 25, 2007 | 08:39 AM
aleicgrant's Avatar
aleicgrant
Default Hub Centric ring question
Needed with all aftermarket rims?
Thanks
Old Sep 25, 2007 | 11:02 AM
aleicgrant's Avatar
aleicgrant
anyone?
Old Sep 25, 2007 | 11:51 AM
tonester1011's Avatar
tonester1011
CF God
no i dont think its needed with all rims....but if they come with them then u should use it...
Old Sep 25, 2007 | 11:54 AM
RedBullRR's Avatar
RedBullRR
I believe anything other then your stock wheel will need hub centric rings. This will prevent the wheel from going on lop sided and giving your car the shakes at 80+ mph
Old Sep 25, 2007 | 11:56 AM
tonester1011
CF God
yea but if u have lug nuts that are sloped on the ends, then that pretty much makes the wheels go on centered....my first set of wheels did not come with them and i was fine...but then my PIAAs did come with them...either way i was ok. most lug nuts now have that little slant on the end of them to center the wheel.
Old Sep 25, 2007 | 01:04 PM
aleicgrant's Avatar
aleicgrant
are the stock lugs sloped?
Old Sep 25, 2007 | 02:13 PM
Thanks
No. You have hub-centric and lug-centric wheels. A google search will give you an explanation of each. Generally, performance sports cars have hub centric wheels. A ring will essentially give you a hub-centric wheel.
Old Sep 25, 2007 | 02:23 PM
aleicgrant's Avatar
aleicgrant
So in other words, buy some rings when I get some new wheels like volk.
Old Sep 25, 2007 | 02:30 PM
Not sure if the wheels are a perfect match for the 350Z, or if you need rings. Ask vendor for assistance.
Old Sep 25, 2007 | 05:00 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
as davidv said, some are hubcentric, some are not - most aftermarket are NOT hubcentric, and will need spacers.
whomever sells you wheels should at the very least tell you this info, if not provide rings
issyz
Jul 2, 2017 03:04 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
