Stock 17" wheel size...
Old Oct 2, 2007 | 08:34 PM
AGent_SaMo's Avatar
AGent_SaMo
Default Stock 17" wheel size...
searched and couldnt find it...how wide are the stock 17s?
Old Oct 2, 2007 | 08:52 PM
Spike100's Avatar
Spike100
OEM 350Z 17" wheel sizes:
Front: 17x7.5"
Rear: 17x8"
These wheels are made from aluminum alloy, and they are suprisingly heavy... about 24 lbs per wheel.
--Spike
Old Oct 3, 2007 | 01:43 AM
Z_Driver's Avatar
Z_Driver
Master
With tires they end up just over 50lbs a position.... Just shipped some so I had to weight.
However, stock 18" are about 53lbs a position..... But, they look so much better imo.
Old Oct 3, 2007 | 05:48 PM
Spike100's Avatar
Spike100
^^ Wow! That’s heavy. I suppose it isn’t too important for 17” wheels with snows (performance isn’t the issue here)… But, stock 18” wheels with this much un-sprung weight is too much if you want decent performance and handling.
EDIT: Thanks for posting this info.
--Spike
Old Oct 3, 2007 | 08:27 PM
AGent_SaMo's Avatar
AGent_SaMo
wow 24 lbs?! i was gunna use em for the track! but now...i dont know...
oh, thanks for all the info guys!
Old Oct 3, 2007 | 10:18 PM
Z_Driver's Avatar
Z_Driver
Master
Actually - I think the 17" are more like 21lbs with the stock tires at 29lbs. Crazy. The 18" are 23-24lbs with stock tires at 28-29lbs. I've never had them seperated but, I'm going on what Tire Rack states the tires weigh and I subtract it from the total actual weight that I measured.
I'm thinking about some Kosei K1 TS 17x8 that are at 15.5lbs. Those should save some weight over stock. Throw some good sticky race DOT's on there and your set. Of course you'll need some sways, shocks and springs next with a upgraded LSD. ;-) See how it goes ... Therefore, I'm waiting just a little bit longer to see what happen for me financially.
Kosei K1 TS Grey ..... I just noticed $129 for 17x9 that you can't get in the gold ones. Man, I like those gold ones ... but for $239 each and you can't even get 17x9's .... I might go with the grey and just paint them or, enjoy them as is.
Oh, heck ... maybe I'll just drill out the stock wheels... Lol !!! I'm such a cheap bastage ....
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
