how will these rims look
hi .. im kinda new to this.. please help.. Motegi Racing Touge 's 18x9 with a 12mm offset //// how is that off set.. what would be the ideal offset for an 18 or 19 inch wheel?
Welcome.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
those calculators are a pain alot of the time.
also, a +12 you will need a bit of camber on to not stick out. also tire selection is important.
but as long as you have suspension parts to set everything up right you will be golden (that is height adjustment and camber/toe adjustment)
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
