wheel spacer question
Old Oct 21, 2007 | 01:16 PM
phorbo007's Avatar
phorbo007
Default wheel spacer question
I have Ichiba 10mm hubcentric spacers installed for the front wheels, and it included extended studs which I installed also. I'm thinking about changing it out with a 15mm spacer instead. Can I just swap the 10mm spacer out, and replace it with a 15mm spacer w/o changing the studs again? I'm assuming the 15mm extended studs are longer than the 10mm studs, though I didn't measure before I installed them.
Old Oct 21, 2007 | 03:07 PM
terrasmak's Avatar
Yes, the 10 and 15mm spacers come with the same studs.
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
