any oe fitted 275/35/18 on his rear Track wheels?
looking for some competition tires and found this size on tire track. Gonna bee used for circuit racing with 245/40/18 up front.
Hoosier 275/35R18s work fine on the rear 8.5-inch track wheels AND the front 8-inch track wheels. Even your local tire company can mount them.
I run 285/30R18 Kumho V710s on all four corners (8-inch and 8.5-inch) on my '05 Track. Yes, they are a pain to get mounted, but they "fit" -- if you let them sit for a month to let them square-up on the wheels.
I've mounted 275/40/17 r-compound tires on four 17x8 stock rims for autocross, so it's not an issue mounting 275s on 8.5" wide rims.
Originally Posted by davidv
The wheel is 216 mm wide. The tire is 275 mm wide. Let me if the tire falls off the wheel.
Yea it will be bigger than the rim. Or it will be to small for the rim. Everyone has OPINIONs
$hit the dub guys thro 105's on 9" rims. Some people are to conservative. I plan on running 265 on all fours on my track rims. I want to see if I can get another set of rear rims. FOr the same on all four corners for rotating purposes. Youll be fine
Chris
Chris
autocross and street tires are completely different animals, the sidewalls are significantly stiffer on autocross/track tires, so are less prone to rollover. A 275 street tire on an 8.5" wheel will have significant bulge, and while it may not physically fail, it can very easily lead to decreased performance due to excessive sidewall flex and rollover from being mounted on too narrow of a wheel.
I've had 275/40 street tires on my rear 8.5 since about month 7 (and 11K miles on the original 245/45s). Now, nearly two years (and several practice and rain events, not to mention another 20K+ miles), I've replaced the 275/40s -- with another set of 275/40s.
StateNuke08
Oct 31, 2015 05:01 AM
hardkicks
Sep 20, 2015 12:28 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
