Will these tires fit 18" OEMs?
Old Oct 28, 2007 | 07:39 AM
d!abolic's Avatar
d!abolic
Default Will these tires fit 18" OEMs?
245-40-18
Old Oct 28, 2007 | 07:59 AM
DavesZ#3's Avatar
DavesZ#3
They will physically fit on the wheel, but they may not work as far as VDC/TCS is concerned. The OEM tires were 245/45/18, not 245/40/18 so those are a little "shorter".
We need a lot more details before determining whether they will work on your particular car and setup.
Old Oct 28, 2007 | 04:57 PM
GodSpeed's Avatar
GodSpeed
Not all there
what about going 245/40/18 front and 245/45/18 rear?
Old Oct 28, 2007 | 05:26 PM
33.5 mm is one hell of a difference in height!
Old Oct 28, 2007 | 05:34 PM
terrasmak's Avatar
You messed up your post its a 245/45 rear not 255/45.
Old Oct 28, 2007 | 05:45 PM
Sorry about that. 245/40/18 front and 245/45/18 rear is better.
Old Oct 28, 2007 | 05:52 PM
DavesZ#3's Avatar
DavesZ#3
Those should work fine as the rears would be about ½" taller than the fronts - well within the limits of what VDC/TCS expects.
Old Oct 30, 2007 | 05:18 PM
d!abolic's Avatar
d!abolic
Wait, so can I go ahead and buy them then?
Old Oct 30, 2007 | 05:56 PM
Spike100's Avatar
Spike100
That depends upon the size of your wheels. Post that info to get the help you need.
EDIT: 245/40-18" will fit the front stock wheels (18"x 8").
--Spike
Old Oct 30, 2007 | 06:13 PM
DavesZ#3's Avatar
DavesZ#3
Spike - his subject line states 18" OEM wheels, so they are either 8" or 8½" wide. In either case, those tires will fit fine.
Old Oct 30, 2007 | 06:29 PM
Spike100's Avatar
Spike100
I wasn't sure if he wanted to mount this size on the front or the rear. 245/40-18" would be the right size for the front (as to overall diameter).
--Spike
Old Oct 31, 2007 | 06:34 AM
z-u-later's Avatar
z-u-later
245/40/18 will work fine on all four corners. For my autocross setup, I have a set of RA-1s on my track trims (18x8 F / 18x8.5 R) and I don't have any issues at all.
Old Oct 31, 2007 | 06:29 PM
d!abolic's Avatar
d!abolic
Nevermind, he doesn't wanna ship.
Old Oct 31, 2007 | 06:34 PM
Spike100's Avatar
Spike100
^^ Yes that size should work on your Enthusiast with TCS.
re> "245/40/18 will work fine on all four corners."
You shouldn't expect this setup to work reliably on a VDC equipped-car.
--Spike
Old Oct 31, 2007 | 07:54 PM
GodSpeed's Avatar
GodSpeed
Not all there
Excelent, Ive been looking for a way to lose some understeer.
Old Oct 31, 2007 | 08:47 PM
Spike100's Avatar
Spike100
^^ Just in case you missed the VDC comment…
Your Performance Model has VDC, and thus requires a staggered setup as to overall diameter. So, your “all square” setup with 18” wheels is:
245/40-18” front
245/45-18” rear
--Spike
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
SharX59
Sep 27, 2015 09:23 AM
