Just had alignment done... How are these specs?
Old Nov 1, 2007 | 05:16 PM
skn5002's Avatar
skn5002
Default Just had alignment done... How are these specs?
I had an alignment done for the first time on my '03 with 19" volks on the car. Got it done at a Firestone since it was right by my school. They were fairly knowledgeable and told me they did alignments on many Z's before, so I felt rather safe going to them. Anyways, here is the print out they gave me. How does everything look and how bad was my alignment before? Did they do everything correctly? Kind of new at reading these, so any input would be great. Thank you!
[IMG][/IMG]
Old Nov 1, 2007 | 05:20 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
That's awesome. I'm hoping mine would be there but it's impossible with my offsets and wheel size haha. I'm looking at getting in the -2.0 range for the rear wheels and I'd be happy
Old Nov 1, 2007 | 05:59 PM
I don't see any difference between the before and after numbers.
Old Nov 1, 2007 | 06:01 PM
DaytonaRoadster's Avatar
DaytonaRoadster
the toe?
Old Nov 1, 2007 | 06:54 PM
redlude97's Avatar
redlude97
Why isn't the actual toe numbers listed?
Old Nov 2, 2007 | 07:54 AM
beeman's Avatar
beeman
Not to mention missing the actual numbers, but Toe should not be measured in degrees as far as I am aware of...
Old Nov 20, 2007 | 08:47 AM
Master Shake's Avatar
Master Shake
You are missing most of the "Acutal" toe numbers -- basically saying what was changed. Your before numbers (for toe) are red, and out of allignment (especially the front left). The toe setting is usually what causes the tire feathering issue.
Old Nov 20, 2007 | 09:50 AM
Zridder19's Avatar
Zridder19
Toe is off, camber is good tho.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
