295/30/19: Can I run 245/35/19 fronts?
Old Nov 2, 2007 | 07:28 AM
GQ 350z's Avatar
GQ 350z
Default 295/30/19: Can I run 245/35/19 fronts?
Hey guys:
Will I have any VDC/TCS issues if I have a 295/30/19 on the rear of my 10.5" rear wheel and 245/35/19 on my 9.5" front wheel? I used to have 255/35/19 in front, but due to an expected lower front ride height, this may have to change.
Thanks, ordering soon.
Ravi
Old Nov 2, 2007 | 07:33 AM
Devil Z's Avatar
Devil Z
Are your fenders rolled up front?
Old Nov 2, 2007 | 07:42 AM
GQ 350z's Avatar
GQ 350z
They can't be rolled. Aren't they rolled from the factory?
If you meant the rear, then yes they are, and then some.
Old Nov 2, 2007 | 07:56 AM
redlude97's Avatar
redlude97
You are correct, I have no idea what Devil Z is talking about
Old Nov 2, 2007 | 04:01 PM
terrasmak's Avatar
Just run a 275/30 up front , its actually shorter than the 245/35.
Old Nov 2, 2007 | 04:07 PM
tonester1011's Avatar
tonester1011
CF God
275/30??? y would he do that? run a 245/35 up front with your 295/30 out back...should be all good
Old Nov 2, 2007 | 04:13 PM
GQ 350z's Avatar
GQ 350z
Will it or not? *Sigh
Old Nov 2, 2007 | 04:21 PM
BhashaZ's Avatar
BhashaZ
I dunno if it will cause any issues, but why not just run the 255/35 again? Trust me, the 245/35 is much easier to damage! I "curbed" mine when a speed bump snuck up on me!
But if you are saying "due to an expected lower front ride height", I don't know how that will affect your ability to run a 255, unless it's going to rub on the inside (which I don't think should be an issue since you have a relatively low offset). Rubbing on the outside should also not be an issue given that if you lower it, you're going to camber inwards anyways, which I would venture to say would possibly make you rub on the inside, but like I mentioned above, I don't think should be a huge problem given that you're running a +19 offset up front.
Anyways, yeah. I donno man
Old Nov 2, 2007 | 04:25 PM
Nexx's Avatar
Nexx
i think he might be asking this question because RE050's come in those sizes at a very reasonable price. i think around $1k for all 4.
Old Nov 2, 2007 | 04:27 PM
BhashaZ's Avatar
BhashaZ
Oh really? Gives me ideas...I really want to run 255/35/19 and 295/30/19 like Ravi did before, but I don't want to go with something expensive like Pirelli, Michelin, etc.
Old Nov 2, 2007 | 04:35 PM
redlude97's Avatar
redlude97
255/35/19 or 265/30/19 would be good choices to match up with the 295 rear
Old Nov 2, 2007 | 04:37 PM
GQ 350z's Avatar
GQ 350z
Actually I have pirelli PZERO Rosso N1's right now, but don't know what to get for the fronts...
Thanks redlude..the 265/30 sounds interesting.
Old Nov 2, 2007 | 04:44 PM
VIZAGE's Avatar
VIZAGE
This would defiantly be ideal IMHO.
Old Nov 2, 2007 | 04:47 PM
GQ 350z's Avatar
GQ 350z
I ran 255's before...what would be a smaller effective sidewall?
lets see ... .35*255...vs .30*265...damn too lazy to calculate lol!
Old Nov 2, 2007 | 04:48 PM
redlude97's Avatar
redlude97
The 265/30 will be slightly shorter than stock. 275/30/19 is a better match, but may be too wide for your tastes and result in slightly heavier steering
Old Nov 2, 2007 | 05:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
295/35 in the rear-pudgy!!!!
Old Nov 2, 2007 | 06:35 PM
MR_X's Avatar
MR_X
I also agree with this. I had 245/35 in the front with a 9.5" rims and they were too stretched out. The outer rim of the wheel would hit the road on hard turns.
Old Nov 2, 2007 | 06:44 PM
ALO8's Avatar
ALO8
do it and let us know, ur the guinea pig
Old Nov 2, 2007 | 09:40 PM
OffsetZ33's Avatar
OffsetZ33
Im running a 265/30 both aggressive and low - I love the look of the 30 series profiles personally - do it
Old Nov 2, 2007 | 09:42 PM
GQ 350z's Avatar
GQ 350z
Yes, so do I, but will these negatively effect my vdc/tcs...? Thanks everyone...
