Does anyone know whats wrong
Old Nov 2, 2007 | 10:51 AM
05Redline's Avatar
05Redline
Default Does anyone know whats wrong
Just got new wheels and tires and swapped the tpms sensors into them but now the psi light comes on and says i have 18psi in my tires but when i go to put air in them and check the pressure its says 35psi. Do the tpms sensors need to be reset when you get larger wheels or what. Anyone else have this problem?
Old Nov 2, 2007 | 11:20 AM
DavesZ#3's Avatar
DavesZ#3
Did you check all 4 wheels? Maybe the one that is reading low got swapped around in the change over to the new wheels.
Old Nov 2, 2007 | 06:01 PM
05Redline's Avatar
05Redline
Yeah all 4 of them are off by about 10-15psi
Old Nov 2, 2007 | 06:14 PM
DavesZ#3's Avatar
DavesZ#3
What did you use to check the pressure, a good dial gauge or a cheap pencil gauge or even worse, one of those builtin gauges on the air hose?
Most cheap gauges can be off by 5-10 very easily. The TPS sensors are rated ±1psi. It's not likely that all four are wrong.
Old Nov 2, 2007 | 06:21 PM
ALO8's Avatar
ALO8
arent you suppose to drive a couple miles after so they can self calibrate?
Old Nov 3, 2007 | 05:13 AM
DavesZ#3's Avatar
DavesZ#3
You don't have to drive them a specific distance, you just have to drive them over 20mph to get a new reading to come through. The sensors only switch on above that speed so the batteries don't wear down when the car isn't moving.
Old Nov 3, 2007 | 09:51 PM
jones21's Avatar
jones21
take it to who ever put it on and have them make sure they didnt break the sensors
Old Nov 3, 2007 | 11:09 PM
DJMatrix1067's Avatar
DJMatrix1067
wait a minute? the sensors have batteries in them? do they ever need to be replaced?
Old Nov 4, 2007 | 05:23 AM
DavesZ#3's Avatar
DavesZ#3
Yes, they (the sensors) will eventually need to be replaced. The rated life for the batteries is 7 years. Because the sensor is a molded unit, you can't access the batteries, the whole sensor needs to be replaced.
Old Nov 4, 2007 | 08:10 AM
HitLines's Avatar
HitLines
I doubt it is the batteries with a shelf life of 7 years. Have any other members reported having to change out the batteries? I would head back to the shop and have them take a look. If they throw up their hands then head to a dealership and send the bill to the crappy tire shop.
Someone messed up somewhere.
Old Nov 4, 2007 | 09:56 AM
blackz7887's Avatar
blackz7887
when i got my new tires the sensors were off by about 5 psi, they reset the sensors and off i went. discount tire will reset them for free.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
