Should i go for a more aggressive wheel?
Old Nov 5, 2007 | 08:17 PM
LT_350Z's Avatar
LT_350Z
Default Should i go for a more aggressive wheel?
I ordered a set of work vs-xx in gold....19x9.5 +23 and 19x11 +29 just recently. Lately on the forums I been seeing all of these threads with reallly aggressive offsets and its making me want to go more aggressive!!! (dam u guys). But I was wondering how much more of an aggressive offset could I go with a tanabe gf210 drop and rolled fenders. I don't want to mess with camber arms or none of that but I really dig huge lips. Can u guys give me some feedback on what will be a good set up? My vendor says it takes about 2 months for the wheels to come in so hopefully I can change my order if I get some good feedback.
Old Nov 5, 2007 | 08:23 PM
redlude97's Avatar
redlude97
I don't see a 9.5+23 or 11+29 setup on the vx-xx application sheet. There are some questions you have to answer before we can recommend a good setup. Do you need to clear a BBK? How much negative camber are you willing to runn front and rear? How much of a roll/pull are you willing to do? What sized tires are you wanting to run, and are you willing to stretch tires to fit big wheels?
Old Nov 5, 2007 | 08:28 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
If you go with 19x11+24 you can get a 5" lip for sure. I know Rick sells VS-XX with the 19x11" setup and you can fit a coke can in there so definitely is 5" and +24 on an 11" rear is plenty aggressive if you got your fenders rolled already. My drop is similar to yours and you can see the +17 fits no problem! I rubs only in REALLY REALLY deep dips in freeway speed. So it's definitely not a daily issue and when it did rub it didn't cut the fender or damage anything.
Check this: https://my350z.com/forum/wheels-and-tires/311953-baller-offsets-huge-lips-for-you-lip-lovers-d-no-56k-3.html
Old Nov 5, 2007 | 08:36 PM
LT_350Z's Avatar
LT_350Z
sorry i mite be a lil off on the offset i gotta call ravspec and ask them again!
no bbk.
i dont kno much about camber please explain.
wat do u mean by roll and pull? (fenders)?
want to run 255/35/19 285/35/19 but dont kno if thats the rite tires to go with.
yes im willing to do wat it takes.
Old Nov 5, 2007 | 08:39 PM
LT_350Z's Avatar
LT_350Z
hey alvin! i love ur set up and ur one of the guys that made me wnat to go more aggressive lol...so if im running 19x11 +24 i should leave the front 19x9.5 +23? btw wat size tires r u running
Old Nov 5, 2007 | 08:40 PM
terrasmak's Avatar
Check this: https://my350z.com/forum/showthread.php?t=311953&page=3
I dont think you could get more prefectly flush than that , to the OP , what you ordered will be just fine, you can adjust a few mm with spacers if you need, but you probably wont have to.
Old Nov 5, 2007 | 08:44 PM
LT_350Z's Avatar
LT_350Z
i jus placed the order last week do u think i can change the offets i want for it still?
Old Nov 5, 2007 | 11:31 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Thanks terrasmak, I think it's definitely the most aggressive I could get at this time without getting out of OE camber specs. After talking to redlude we are both convinced that a 19x10 and a 19x11.5 Meister S1 would work, it would be 19x11.5+23 O disk in the back as oppose to mine 19+11+17. We would keep the same lip and outer piece but extends the inner half by .5"! That would be soooo sick!
Thanks for the compliment bro but I definitely have to thank Hai (redlude97) for pushing me to get the lower offsets and it was worth the wait! I definitely think the 19x9.5 +23 is perfectly fine. That's what I have right now and I love it. I prefer the front not to have massive lipage because I like how it's moderate and makes the back look even nicer. If you have a huge front lip it makes the back lip not look so big.
As for the order I am not too sure, last time when I got the order placed by Rick he sent it directly there and the work started pretty much immediately. After that 2 months from the day the order was made I got my wheels from Rick so technically it only took them 7 weeks to make it and 1 week to get tires mounted and shipped to my door steps. You should call the shop immediately and ask if you can change the specification on the wheels.
Old Nov 5, 2007 | 11:36 PM
LT_350Z's Avatar
LT_350Z
thanks a lot for all the help! im gonna call the shop tomorrow asap and ask if i can change the specs on the wheels...sounds like im gonna go with 19x11 + 24
Old Nov 6, 2007 | 12:40 AM
redlude97's Avatar
redlude97
I think you are looking for 19x11+23 with an o-disk. For the front I would go 19x9.5+19 with an A-disk also so its more flush. I don't even know where the 9.5+23 is on the offset sheet they are referring to. Ask them what center disk that is for.
Old Nov 6, 2007 | 01:00 AM
LT_350Z's Avatar
LT_350Z
they told me its on the O disk...ill prob try the offset ur talkin about..from wat i hear from alvin u kno ur stuff! and ill mention the A disk to them for the fronts.
can u give me a calculation of the lip size ill b lookin at?
19x9.5 +19 A disk
19x11 +23 O disk
for the offset i posted earlier...he said i should have a 3.3" lip in front and 4.3" in rear
Old Nov 6, 2007 | 05:11 AM
hatchboi's Avatar
hatchboi
can yall explain what an O disk and an A disk means? im also looking into new wheels with very aggresive offset. sorrie if i am intruding in your thread LT.
Old Nov 6, 2007 | 08:48 AM
LT_350Z's Avatar
LT_350Z
hey guys...jus got off the phone with ravspec...turns out these were the specs i was gettin
19x9.5 +25
19x11 +23
but he then told me i was only gonna get a 3.8" lip not a 4.3" lip cuz he read the application wrong...so i asked him to change the order to 19x11 +17 in rear and then i can get the 4.3" lip but hes gotta call work and see if they have started workin on the order yet. *cross fingers*
Old Nov 6, 2007 | 08:51 AM
redlude97's Avatar
redlude97
I think he had the offsets backwards. If you were to run an Odisk front and rear, then there is a 19x9.5+29 with a 87mm(3.3-3.4") lip, and 19x11+23(4.3-4.4") lip. The fronts are really conservative though, and I would run an A-disk instead with the same sized lip, which is the 19x9.5+19A disk which I recommend previously. That has the same 87mm lip, but allows for more brake clearance as well as making the wheel flusher. Unfortunetly you can't go to a wider lip unless you want to get significantly more aggressive(19x11+10). But at least with this new setup it will be flush with the wheel wells.
Old Nov 6, 2007 | 08:52 AM
redlude97's Avatar
redlude97
19x9.5 +25
19x11 +23
Dude, I don't know what spec sheet he is looking at, but I don't see a 19x9.5+25 on there.
Old Nov 6, 2007 | 08:53 AM
LT_350Z's Avatar
LT_350Z
hey where r u gettin this info from? i need to look at wat ur lookin at to get an idea of offsets and lip sizes...im sure it'll help me out a bunch hes still gotta call me and veryify wat i want exactly so ill let him know
Old Nov 6, 2007 | 08:57 AM
redlude97's Avatar
redlude97
Go here for the vs-xx spec sheet
http://www.work-wheels.co.jp/product...e67a1cd03926af
Old Nov 6, 2007 | 09:00 AM
LT_350Z's Avatar
LT_350Z
ok im on the phone with him now...gettin everything cleared up
19x11 +23 O disk
19x9.5 +19 A disk
thanks a lot redlude u helped me out major i couldnt thank u enuff. u were correct about all offsets and sizes
Old Nov 6, 2007 | 09:08 AM
redlude97's Avatar
redlude97
19x11 +23 O disk
19x9.5 +19 A disk
Glad it worked out for you. Post pics when you get em! I suggest 255/35/19 and 285/35/19 tire sizes for those width wheels also. Thats what Alvin is running and it looks great on those wheels.
Old Nov 6, 2007 | 09:48 AM
LT_350Z's Avatar
LT_350Z
yea that was the tire set up i was planning to run...thanks once again!
