Tire Pressure Warning!
Old Dec 23, 2007 | 08:11 PM
maXmood's Avatar
maXmood
Under Boost!
i got the PSI on last night. temp was 60, PSI where (F30,R28). i'm assuming that i have to put more air in those tires?
PS: i got stocks on.
thnx
Old Jan 4, 2008 | 04:09 PM
dhwang80's Avatar
dhwang80
i know stock cold tire pressure should be 35.
with it being 40 and below...recently in the upper teens....
should i inflate it to 38 cold to accomodate or leave it at 35 cold?
nevermind. i read some other articles and found out I should always have it at 35 cold regardless of outside temps
Old Feb 22, 2008 | 05:28 PM
blazz's Avatar
blazz
hi, my alarm light don't want to go off...I put back 35psi to all the tires (my car is store for the winter) want for a ride but that light still there even if the pressure is good
got any solution for me ? thanks
Old Feb 23, 2008 | 04:32 AM
Spike100's Avatar
Spike100
^^ One of the sensors might be faulty.
Since you store the car during the winter, I wouldn’t do anything until you take it out this spring. If you have the light then, I would have the sensors checked.
--Spike
Old Feb 28, 2008 | 08:07 AM
blazz's Avatar
blazz
--Spike
good idea, thanks
Old Apr 8, 2008 | 05:18 AM
blazz's Avatar
blazz
eh eh spike100, I just take it out for a run and the light is now off, thanks for the advice
Old Apr 8, 2008 | 03:18 PM
Spike100's Avatar
Spike100
Thanks for the update. That helps all of us learn. Glad to hear it is working.
I’m guessing, but here is what might have been going on. The sensors are activated by centrifugal force when the tires begin rotating (that’s why you do not get a reading until driving a short distance). I suspect that one of the sensors was sticking due to the cold temperature.
--Spike
Old Apr 17, 2008 | 09:33 PM
HadesMR's Avatar
HadesMR
I bottomed my car out on a ramp in Alabama and it hit the ground pretty hard, had a light on since, think it's the sensors? My PSI thing keeps beeping and stuff, but it was also cold there, colder than the normal Miami, FL weather, so... blah, I just bought it and I have no manual, any help would be appreciated.
Old Jun 1, 2008 | 06:49 AM
blazz's Avatar
blazz
if all the pressure are good in the tires and it flash, probably the sensors...try to look wich one and go to a garage
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
