18x9+25, 18x10+25 as Wide as Possible
I have Work Meister S1 3p.
Spec.
F: 18x9 +25
R: 18x10 +25
What's the widest tire size that I can mount on this spec. wheels without rubbing, rolling, any modifications? I was thinking 255/35 on front and 295/35 on rear.
I have a 04.5 Touring Roadster. Stock tire sizes were 225/45/18 & 245/45/28 but that doesn't really help. Anyone knows the stock wheel spec. for my Z including the offset numbers? Then I can use one of those fancy offset calculators to find out myself.
Thanks.
Spec.
F: 18x9 +25
R: 18x10 +25
Thanks.
Don't u think that profile is too low? I don't mind my speedometer gets throw off but that will also make my odometer read about extra 69 miles higher for every 1000 actual miles I run...
Originally Posted by r_seng
hey there asian rambo. yuo can run a 35 sidewall but how much camber are you willing to live with?
EDIT: Thinking about TEIN S. Lowering Springs...
Spec.
F: 18x9 +25
R: 18x10 +25
Thanks.
Spec.
F: 18x9 +25
R: 18x10 +25
Thanks.
Originally Posted by dkmesa350z
your speedometer will read more accurate with a 295/30 opposed to a 295/35 - the series of the tire is all dependent on the width, so a 295/35 has a taller sidewall than a 275/35
Originally Posted by davidv
An offset calculator will not help with tire selection.
Thanks for the helps/informations/words guys!
I think I should go 255/40/18 and 285/40/18, sounds good?
http://www.miata.net/garage/tirecalc.html
Originally Posted by Arnold K.
Yes and no. The front is just perfect. But the rear should be 275/40-18 for a flawless match, as well, with a mere 0.1% error.
Originally Posted by Korki Buchek
This is correct. Unfortunately only two known companies make UHP Summer tires in a 255/40
A 295/35/18 on a 10" +25 rim will rub unless the lip is rolled. I have a 295/30/19 on a 10" +25 wheel and it will rub with camber in spec.
For a 9" +25 front wheel a 275/35/18 tire is the one to go with. 255 is too narrow. I am running a 275/30/19 front on a 9" +22" tire and it fits perfectly with no rubbing.
JET
JET
JET
JET
In relation a 10" wide wheel with a +25 will give another 3mm of clearance on the fender size. The OP should have NO issue running a 295 if his 10" wheel is a +25 offset
Originally Posted by Zivman
I am running a 295/35/18 on a 18x10.5 +28 and it is just fine. I am running around -1.2* camber <-which is very nuetral.
