Will these sizes/offsets clear BBK
Old Nov 11, 2007 | 07:29 PM
G Thizzle's Avatar
G Thizzle
Default Will these sizes/offsets clear BBK
FRONT: 20x9.5 + 15
REAR: 20x11 +25
Just wondering if these offsets will clear BBK and or Brembos...thanks!
Old Nov 11, 2007 | 08:20 PM
Zivman's Avatar
Zivman
Originally Posted by G Thizzle
FRONT: 20x9.5 + 15
REAR: 20x11 +25
There is absolutely NO WAY for anyone on this board to offer any definitive help for you unless you post the brand and model of wheel and possibly even the disc of that wheel. On top of that, what size BBK?
Old Nov 11, 2007 | 09:31 PM
G Thizzle's Avatar
G Thizzle
Work Varianza T1S... i thought the sizes and offsets would be enough...sorry i didnt give anyone on this board enough detail...
Old Nov 12, 2007 | 08:32 AM
You can use an offset calculator, and compare the OEM Track wheels (Brembo) with the wheels that you are considering. But, as Zivman mentioned, that will not take into consideration variables such as spoke design.
Old Nov 12, 2007 | 12:38 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Big caliper clearance is not based on offset, it is based on pad type.
Old Nov 12, 2007 | 02:26 PM
mich's Avatar
mich
like andy mentioned, brake clearance is not based on offset, its based on pad type.
for the works the Rdisk should be oki for the front and O-disk for the rear. or u can go Rdisk front and rear if youre gonna need more clearance on the rear also.
i would recommend verifying this with your supplier prior to ordering tho. otherwise you may get stuck having to use spacers to provide enough clearance for your brakes.
hope this helps.
Old Nov 12, 2007 | 08:32 PM
G Thizzle's Avatar
G Thizzle
Thanks Mitch... the wheels are R Front and O rear... trying to see if they will clear a Rotora 6potF 4potR with 14" rotors all the way around...
Sleeper_Z
Sep 30, 2015 10:25 AM
