aftermarket VS. stock TRACK light wheels
Old Jun 3, 2003 | 04:41 PM
NoRulzat140 MPH's Avatar
NoRulzat140 MPH
i love the support and interest u guys are giving me, but i simply cannot afford any of that. not for a very long time, OWNING the z will take up 80 85% of my $$
Old Jun 3, 2003 | 10:11 PM
joust75's Avatar
joust75
Originally posted by PoWeRtRiP
The numbers on the brembos are not that much greater than stock. I have seen an average of only 3-5 less ft of stopping distance. Basically the bremmbos are good only if you plan on tracking your z because they do significantly reduce brake fade. If you really are concerned about stopping distance though the best upgrade is tires.
Complete BS. If you drive aggresively you need the Brembos. take it from me. On other cars I have owned, my rotors have warped, and not because I ride them.
YES the brembos do decrease stopping distances significantly . Please can someone supply hard #s?
One more thing; To claim that a tire upgrade is better for stopping distance than a brake upgrade is sheer idiocy, unless your upgrading from 180s to 245s!
No offense but this sounds like someone trying to justify why he didnt get the track model, but secretly wishes he did!
Old Jun 3, 2003 | 10:15 PM
joust75's Avatar
joust75
Originally posted by 2003z
One problem, the base is 26000, for that 28000 you get the enthusiast, which has the LSD and Xenons
I believe I tried to prevent this!
(Please, no know-it-all corrections! these are approximations that are close enough!)
Old Jun 3, 2003 | 11:26 PM
ares's Avatar
ares
Veteran
ok, well hard numbers then were posted, it was a test by stoptech I think, but they tested regular vs brembo vs theres, brembo and regular were within 3 feet after 10 stops from 60mph, they managed to get slightly more difference after 10 stops from 100... so according to hard numbers, the difference between them would take MAJOR track use to see a difference. way more than a typical autocross could provide even.
as for traction not affecting stopping distance, in a single stop, both brakes engage ABS, meaning both brakes can stop the car so quickly that the tires lock up, indicating that with more traction, youd be able to stop shorter, and that is more or less the ONLY way to shorten stopping distance.
new brakes cures fade.
new tires reduces stopping distance.
Id bet 20 $ I could stop shorter than a track with my aftermarket tires and stock brakes. probably take 10 stops before the 2 could even break even.
take it or leave it.
Old Jun 4, 2003 | 05:28 AM
2003z's Avatar
2003z
$2000 and you bling-caching options were very far from close enough.
Old Jun 4, 2003 | 06:21 AM
350z4steve's Avatar
350z4steve
why would you try to prevent this? regrets?
Old Jun 4, 2003 | 07:31 AM
NoRulzat140 MPH
yes rubber will ALWAYS help stopping.... also true what the otha kat said, the brembo's distanes arent that different than 3-5 feet, which i mean..... its still less, but they show virtually no brake fade. which is their advantage
Old Jun 4, 2003 | 09:24 AM
ares's Avatar
ares
Veteran
They performed 20 stops per car.
The averages were:
60-0 100-0
Stock Perf. model 118.01 333.57
Stock Track model 117.28 328.30
ST 332mm front 115.83 326.87
ST 355mm front 115.08 326.16
how incredably different...
I will be the first to say the track brakes stayed cooler, but it didnt seem to hurt the performance model too much...
Old Jun 4, 2003 | 06:23 PM
TJZ's Avatar
TJZ
No offense, but this sounds like someone trying to justify why he got the track model.
Just playing with you (b/c you did get owned )
Old Jun 4, 2003 | 07:16 PM
joust75's Avatar
joust75
LOL I knew someone would turn that one around on me!
But seriously folks, I consider my track model money well spent.
To Each his own
Old Jun 4, 2003 | 07:25 PM
joust75's Avatar
joust75
ONLY $20!!!????
Old Jun 4, 2003 | 07:55 PM
TJZ's Avatar
TJZ
To Each his own
yea, you know, i just had to .
btw, your track model is money well spent.
peace,
-TJZ
Old Jun 5, 2003 | 12:51 AM
ares's Avatar
ares
Veteran
all zs are money well spent, no bad deals out there, so many ways to go from point A to point B.
Old Jun 5, 2003 | 06:58 AM
n8vz's Avatar
n8vz
selecting models depends on what you want to do with the car. If you want to individualize you car with more unique setup(wheel, suspension, electronics)..then Base is probably best [althought..you would miss out on the Xenon HD and aftermarket units are $$$ the last time i checked] or perhaps Enthu. trim.
Old Jun 5, 2003 | 08:32 AM
rktjhn's Avatar
rktjhn
Default braking systems
We have 3 of us that AutoX here around SLC, 2 of us have the track model and the other is an Enthusiast(sp), anyway at the last race he was having problems with his version of the traction control, and was having to pull the fuses on his ABS system, the 2 of us with the track model have not run into that problem.
Anyone have a guess on how to get some camber into the front end? We all have found problems in that we are running on the outer 2 inches of the tires in turns, we have been playing with tire pressures, and one has been experimenting with toe out. I took mine into Nissan and found the alignment was all wacked out, they reset it for free, but the front has to be set at o.o4 degrees in to get any Neg camber at all.
Any help appreciated! John
Old Jun 5, 2003 | 09:02 AM
ares's Avatar
ares
Veteran
I thought I read that if you remove the front brace itll get some camber in there for ya, but thats hardly the optimal solution. not sure there you can really get any useful amount of camber with stock parts. just like you cant get rid of the rear camber.
Old Jun 5, 2003 | 09:10 AM
NoRulzat140 MPH
wtf is camber exactly>?
Old Jun 5, 2003 | 09:27 AM
  #38
NoRulzat140 MPH
i just saw a video from the racing forum, and looking at the g35c, id love the g35 wheels on my z...whatta ya think? same size? wieght?
Old Jun 5, 2003 | 09:29 AM
  #39
ares's Avatar
ares
Veteran
yeah, same size and weight as the performance rims of course, not track. not positive about width, but I think its the same.
I think the swap has been done before.
Old Jun 5, 2003 | 09:31 AM
  #40
NoRulzat140 MPH
is track wheels wieght significantly diferent?
