aftermarket VS. stock TRACK light wheels
If twelve oclock is 0 degrees then 1 oclock would be negitive on the driver side and 11 oclock would be neg on the pass side. You need some neg to help the tire hold contact with the pavement. Too much pos or neg and then only part of the tire is in contact, inside or out side. Look at a road race car and you can see what neg camber is, the bottom of the tire looks tilted , with the top closer to the frame. Toe in is easy, and caster is like your bicycle forks when you where a kid, if the forks lean away, you get a smoother ride, if you turn them around the steering was very jerky.
Hope that helps explain it a little.
John
John
etkms
Jun 19, 2022 06:30 PM
hardkicks
Sep 20, 2015 12:28 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
350z, aftermarket, buying, coupe, g35, light, lite, rims, stock, track, tracklight, tracklightwheelscom, wheel, wheels, worth
