17x10 +20, with 275's, will it fit in the front???
Old Nov 21, 2007 | 02:36 PM
Axelerate's Avatar
Axelerate
Default 17x10 +20, with 275's, will it fit in the front???
I can get a great deal on a set of 17x10's +20 rims!
I would be using them for my 275/40 Hankook R compounds only! Not a street set-up.
I run -3 camber front and -2 on the track.
So, I'm wondering how the fitment will be in the front???
Currently I am running 17x9's +22.
Thanks for the help!
Old Nov 22, 2007 | 02:44 AM
Axelerate's Avatar
Axelerate
Anyone???????
I know 17x10's with a +25 will fit, but not sure about a +20 rim. Let me know what you think.
Old Nov 22, 2007 | 06:42 AM
westpak's Avatar
westpak
SFZCC
well in the rears you should be ok specially with the negative camber
the fronts will be close, just compare them to your current setup they will stick out about 5/8's of an inch more, a -3 camber in the front is a lot so it will probably be ok
Old Dec 1, 2007 | 06:34 PM
creationv2's Avatar
creationv2
should fit perfectly in front...and tucked in in the back...+2 from is like .5-1 inch, and 9.5+22 fit perfect
and +1 your camber will more than compensate if it were too wide.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
