what would u do if GTS wont fit.
Originally Posted by AlvinHuyN
that doesn't make any sense. If you had them cut you'd have even MORE clearance then someone with just rolled fenders.
So you're saying that with this set up you're rubbing....because you're dropped
-Cut fenders, 19x10.5+18 & 285/35/19 - drop unknown (but doesn't really matter in this case anyway, you'd still have plenty of clearance)
While I'm NOT rubbing at all with the following setup
-Rolled fenders, 19x11+17 & 285/35/19 - dropped ~1.25" camber can be set at -2.0 (OE spec) w/o problems
You must be running positive camber or something to make them rub man!
Originally Posted by emulzhn
some of you may have read my recent post re: problems with my wheels fitment (volk GTS 10.5 +18 on T1R 285/35/19). I believed in what most of you said as proof of your rides. So I insisted that fenders be rolled/ shaved but my installer is now...just refusing and claims that damage is inevitable. No prob...I'll just go to another guy...
now...discussion is over with current dimensions...
I really like the rims and tires and definitely do not want to rid off but will switch tires if needed.
what should I do:
1. rid off gf210 and replace with hotchkis, (decreasing the drop)
2. trade tires for 285/30/19. will this look funny as profile is smaller at rear.
3. switch to other tire manufacturer like falken
criteria
hate stretched look
suggestions pls....
what should I do:
criteria
hate stretched look
suggestions pls....
Otherwise, you have 2 routes you could take ...
Easy route: Just listen to all those nice folks who told you to put on 275's in rear = $
Harder route: You could roll / cut your fenders with a negative camber adjustment = $$$$$
OR....
Alternative route: If you are planning on a major face lift of the Z, just go wide body then the problem will be fully solved << That was the option I chose, Planning on running +2 offset with 295's ~ 305's if possible
As far as rolled fenders / cut fenders + 285's, it will most def. rub on a Tanabe lowering springs for sure.
Originally Posted by Changvi
Buy a set of GTS like CEO350Z and run 285/35/19 in the rear, then tell us if it will rub. I will guarantee you your answer will change.
^ I have the GT-S on order and I had few questions for you. One of the reason I bought these wheels is because I wanted the aggressive look for my Z. I planned on running 285s and now I'm a little bit worry. Reading here sounds to me like 285 can work with fenders rolled. That's good. But how does it look from the back? Can we see a straight shot of your Z from the rear? also, what's your set up?
Anyone running 275s - Can you show us a pic of this stretched 275s? I think it's going to help us better.
Ok. This is for everyone who is considering GT-S' in the +17, +18 Offset. Here are the options and the consequences of each to my knowledge.
1. Going 275/35/19 in the rear. You might not have rubbing issues on springs with an aggressive drop. GF210, Hotchkiss, Dropzone, etc.
Pros: No rubbing. The tire will not stick out of the wheel well.
Con: Tire will looked streched. Less tire on the ground.
2. 285/35/19 This setup is good for those with less aggresive springs like Tein, etc. I would recommend that the fenders be rolled. You might not have too, but for the JIC Factor, I would definetly do it.
Pros: More tire on the ground. No streched look. Tire gap is clean.
Cons: Negative Camber, the wider the tire the more negative camber on stock components. Tires wear unevenly. The tires stickout of the fender wells by about 5mm.
3. 295/35/19 I would only recommend that if you have your fenders rolled and have an aftermarket camber kit. This way you have complete control of your camber.
Pros: Even More Tire on the ground. Full coverage of tire on the wheel.
Cons: The tire will definetly stick out. If you don't have a camber kit, your camber will be bad.
4. 285/30/19 Although you are running a lesser profile, the wheel gap will be greater. You also still run the risk on big bumps at high speeds.
Pros: Less likely to rub tire.
Cons: Less profile means less tire. Tires wear faster. You might still rub with unrolled fenders.
This is recommendation.
EnjukuRacing
Sep 11, 2015 08:30 AM
slimjim888
Mid-Atlantic Marketplace
Sep 9, 2015 06:07 AM
