25mm spacers finally on Pic.
Old Nov 23, 2007 | 07:43 AM
Z04's Avatar
Z04
sorry, but i fail to see any difference at all
Old Nov 23, 2007 | 08:30 AM
cambo350z's Avatar
cambo350z
Originally Posted by Ilov350ZEE
oh damn tell more about it, now im worried
i put it on both spacer lugs and wheel lugs
ride looks good...but why loctite on the whee lugs?
Old Nov 23, 2007 | 09:05 AM
black06z's Avatar
black06z
Looks like you could've went farther out. What suspension are you using?
Old Nov 23, 2007 | 11:54 AM
Ilov350ZEE's Avatar
Ilov350ZEE
/\ tanabe GF210/tokico D spec
Can someone pls. tell why its not a good idea to put tread lock? Actually i used different brand not locktite its blue medium strength.
Strength
Old Nov 23, 2007 | 11:59 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Can someone pls. tell why its not a good idea to put locktite tread lock?
It's going to be VERY hard now to take your lugs off. Locktite is usually used for things that will never get removed.
Old Nov 23, 2007 | 12:02 PM
deezz's Avatar
deezz
Damn...that sucks. Never used locktite, but now I now how it works.
Old Nov 23, 2007 | 12:32 PM
Ilov350ZEE's Avatar
Ilov350ZEE
i think i'll be alright, i just have the medium strength. It says on the package
service removable, and on the back says common application is mounting bolts.
Old Nov 23, 2007 | 01:07 PM
cheshirecat79's Avatar
cheshirecat79
The threadlock is going to be a pita to break, you're just going to have to use a ton of leverage to get it off. For future reference, it's not needed at all for the spacers.
Old Nov 23, 2007 | 08:09 PM
Chebosto's Avatar
Chebosto
Loctite Blue or Red is breakable, just when you end up deciding on changing out the wheels later, you'll have to clean the threads on the studs pretty well.
if you put the lugs on and use a TORQUE wrench and properly set for the correct force, you should not worry about them coming off.
i actually use anti-seize on the studs to make sure i CAN take off my lugs later (in case it rusts)
Old Nov 23, 2007 | 09:58 PM
dutchboy350Z
Finally some go
+1
I torqued mine to 90 lbs. Just for gits and shiggles, after about 1k miles, I took off my wheels to see if my spacers needed to be retorqued. Every lug nut was still tight and didn't need it.
Old Nov 24, 2007 | 02:14 AM
undrgnd's Avatar
undrgnd
Sorry, I can't see any difference either, though I'm sure there must be. Why did you do that? I'm just curious...
Old Nov 24, 2007 | 05:41 AM
cheshirecat79
Without before and after pictures it's kind of hard to tell. However, there is a large difference.
Old Nov 24, 2007 | 11:26 AM
DelayedZ's Avatar
DelayedZ
Ya a huge difference I want to get spacers freakin bad, lol...basically for those of you who can't tell the difference, normally the z's wheel is well under the quarter panel, lol...now it's pushed pretty much even, he could of gone out a lil farther in the rear actually. Still looks good and gives the car a much nicer stance when looking at it.
Old Nov 26, 2007 | 09:31 AM
tmounk's Avatar
tmounk
You must need glasses if you can't tell the difference with the spacers and without spacers. I have track wheels and can't wait to get some spacers, just worried because of mixed reviews. Now that I have coilovers, the gap is more noticable.
Old Nov 26, 2007 | 10:16 AM
cheshirecat79
What mixed reviews? I haven't seen any people post negative reactions after installing spacers. It's either "I can't tell the difference" or "Wow that looks so much better, the car should come like that from the factory" .
Old Nov 26, 2007 | 11:10 AM
tmounk's Avatar
tmounk
This one!
https://my350z.com/forum/brakes-and-suspension/311286-calling-all-owners-with-wheel-spacers-adpaters.html
Old Nov 26, 2007 | 01:16 PM
cheshirecat79
The symptoms he was describing in that thread are synonomous with using spacers that aren't hubcentric, or using spacers with aftermarket wheels and not seating the hubcentric rings for the wheels properly.
As long as you purchase the right spacers you'll do fine.
Old Nov 26, 2007 | 02:21 PM
  #38
tmounk's Avatar
tmounk
I have the 1st gen track wheels, and was thinking of getting the H&R 25mm all around. I should be good right?
Thanks
Old Nov 26, 2007 | 04:52 PM
  #39
cheshirecat79
Thanks
It will look fine.
Old Nov 27, 2007 | 08:41 PM
  #40
ncparamedic's Avatar
ncparamedic
Prodigal Son
If you dont mind me asking..how much did you pay for the spacers?
