Anyone got 275's all around?>
Old Nov 22, 2007 | 02:45 PM
Al_s14's Avatar
Al_s14
Default Anyone got 275's all around?>
just curios what your opinion is. i am about to get a set of 18x9.5 G-games(20off) and have hard time deciding if i should get 275 all around b/c they end up being cheaper then going with 255 front and 275 rear.
by the way i am looking in to Falken Fk452 which are at 139ea
all input appreciated thanks!
Old Nov 22, 2007 | 03:24 PM
SniperHunter's Avatar
SniperHunter
Where can you get it for 139?
Edit: Nm, Edge.
Old Nov 22, 2007 | 04:42 PM
Same size tires all around with VDC? Best of luck.
Old Nov 22, 2007 | 04:48 PM
ppw350Zunit's Avatar
ppw350Zunit
why not 265/35 all-around?
- advan ra3-dt
- 18x10 +19 all-around (+14 offset when you add the 5mm spacers)
- 265/35 falken rt615 all-around
Old Nov 22, 2007 | 05:00 PM
OffsetZ33's Avatar
OffsetZ33
Maybe he has a base model... either way your posts are really starting to irritate me, but maybe Im just easily annoyed
Old Nov 22, 2007 | 05:08 PM
Al_s14
Additional Information
Date of Birth:
July 16, 1984
23
Z/G Owner:
z
Virginia Beach
Color:
Black
Trim Level:
03 Touring
Occupation:
Infiniti Tech
Of course this may be an automatic without VDC.
Old Nov 22, 2007 | 05:34 PM
Al_s14's Avatar
Al_s14
Its is a 6spd... no autos till i retire and even that its not likely to happen
Yes those prices are from edgeracing.com i had good luck with them last time i ordered those tires.
As far as VDC goes, i drive with VDC off most of the time ... hit that button is usualy first thing i do when getting in the Z. I just hate the way it bogs when i do a hard launch or spin through 2nd with VDC on so i try to turn it off unless its rainy outside. It makes it feel like i dont know how to drive stick(you know ge that back and forward bucking).
The bottom line is i dont know if driving experience will be effected in any way and i wanted to hear it form someone with that setup first hand. I like the fact that i can rotate the tires just in case i bent a wheel or somethign that sort.
O yeah i LOOOOVE that white z but i want to stick with at least 40series tires to protect m,y wheels the best. Roads around here suck.
Old Nov 22, 2007 | 05:42 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
OP, you don't say what profile you want to run F/R.(you posted while I was writing, please disregard)
Looking at ppw350zunit's, notice how the front wheel sticks out from the fender? Well a 275 tire is going to have less stretch and may not tuck into the fender during suspension travel. So you really need opinions from someone running 275s on the +20 up front to see if there is any rubbing. Falken tires tend to be on the narrow side for their size so this may not be an issue, but it's hard to say.
I am currently running 275/35/18F & 275/40/18R and this diameter stagger is more than stock F to R and has not been known to upset VDC or TCS. My wheels are +30 so the fronts seem flush and the rear are a bit sunk in (I want some 10mm spacers back there at some point).
My thoughts are, it works great for mountain driving and autocross and there are no negatives on regular street driving over stock as long as you get a tire with good water channels in them (the FK452 seem good). They eliminate understeer entirely but also keep in mind if you end up getting swaybars as set your adjustments accordingly.
Others have also run 265/40 and 265/35 up front as well so there is all kinds of choice out there, just make sure you keep the backs slightly taller than the fronts to keep the VDC happy.
Chris
Old Nov 22, 2007 | 06:05 PM
ppw350Zunit
btw, i've never had a problem with the vdc with my current set-up.
Old Nov 23, 2007 | 09:12 AM
terrasmak's Avatar
- advan ra3-dt
#1 answer , cause its to short of a tire.
Old Nov 23, 2007 | 09:25 AM
z-u-later's Avatar
z-u-later
As long as the tires are the same size all around or the rear tires are slightly taller, it should not affect your VDC. I run 275/40 on all four corners for autocross without any problems.
Old Nov 24, 2007 | 11:59 AM
roger22's Avatar
roger22
Default 275's
I just put 275's on today and the fronts rub. I have the Rota 18X9.5 with 20 offset and they do rub with stock ride height in the turns. I might put 265's on the front or change wheels???
Old Nov 24, 2007 | 12:02 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
It works just fine. As long as the size of the tire ratio is the same, VDC won't complain. Friend has 275 all around on 17s and it's a GT model, no problems with VDC.
Old Nov 24, 2007 | 01:15 PM
Al_s14's Avatar
Al_s14
are you lowered and do you know where it rubs exactly? fender liner maybe/?
Old Nov 24, 2007 | 02:43 PM
terrorist22's Avatar
terrorist22
I have an 06 Base, running 275/35/18 all around without problems. Of course, my car isn't lowered...
Old Nov 24, 2007 | 04:38 PM
DC350ZTrack's Avatar
DC350ZTrack
I have an '04 Track lowered on Hotchkis springs and Tokico DSpec shocks. I'm running Nismo 19x9.5 all around with 275/30 up front and 275/35 out back (Michelin Pilot Sport PS2s). I've been running this setup for 2 years, including mulitple track days without a single problem, so just be careful picking the wheel and offset and you should be fine. GL!
Old Nov 24, 2007 | 07:25 PM
roger22's Avatar
roger22
Smile a
Stock ride height!!
20 offset on 18X9.5's....
Old Nov 24, 2007 | 09:50 PM
AroundMyHorn's Avatar
AroundMyHorn
Stock ride height!!
I was dropped one inch and I still never rubbed. strange.........
Old Nov 24, 2007 | 10:17 PM
plumpzz's Avatar
plumpzz
I run 265/35 front, 275/40 rear. Its the best setup for me because it has neutral steer feeling, its still comfy and theres a lot of tire to protect the rim.
Old Nov 24, 2007 | 10:37 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Powerhouse Amuse ran 265 tires all round, and from the looks of things, there pretty quick (not that your looking for speed around the track).
