Anyone got 275's all around?>
Old Nov 25, 2007 | 01:07 AM
Triple8Sol's Avatar
Triple8Sol
I ran 275/40/17 R-comps all around on my 17x9 race wheels. If you drive with VDC off all the time, you should invest in the KP Technologies unit.
Old Nov 25, 2007 | 09:01 AM
roger22's Avatar
roger22
Default 18
The fronts only rub under hard cornering...
Old Dec 14, 2007 | 12:49 PM
iStan's Avatar
iStan
ZR
Originally Posted by Al_s14
just curios what your opinion is. i am about to get a set of 18x9.5 G-games(20off) and have hard time deciding if i should get 275 all around b/c they end up being cheaper then going with 255 front and 275 rear.
275/35 275/40 Falken 452s on 9.5s all around for me. Cornering is so much more fun
Old Dec 14, 2007 | 11:11 PM
terrasmak's Avatar
Originally Posted by istan
275/30 275/40 Falken 452s on 9.5s all around for me. Cornering is so much more fun
Trust me your fronts are 275/35's
Old Dec 14, 2007 | 11:13 PM
Nexx's Avatar
Nexx
Originally Posted by davidv
Same size tires all around with VDC? Best of luck.
easy, 275/30 front, 275/35 rear = vdc happy. you are getting very annoying.
Old Dec 15, 2007 | 09:34 AM
iStan's Avatar
iStan
ZR
Yes they are, typo.
Old Dec 15, 2007 | 03:38 PM
laze1's Avatar
laze1
What actual offsets are you running?
Originally Posted by DC350ZTrack
I have an '04 Track lowered on Hotchkis springs and Tokico DSpec shocks. I'm running Nismo 19x9.5 all around with 275/30 up front and 275/35 out back (Michelin Pilot Sport PS2s). I've been running this setup for 2 years, including mulitple track days without a single problem, so just be careful picking the wheel and offset and you should be fine. GL!
laze1's Avatar
laze1
Old Jan 9, 2008 | 02:26 PM
DC350ZTrack's Avatar
DC350ZTrack
Kickstarting this thread again... I believe the Nismo offsets are +30 - so that's what I'm running all the way around(no spacers).
Hope that helps.
Old Jan 9, 2008 | 07:52 PM
terrorist22's Avatar
terrorist22
I run 18 x 9.5 +22 all around, w/ 275/35/18's. No rubbing on daily driving, even when I hit huge dips. I didn't ask my shop how much I'm lowered since it was really late and I had to get home, but pretty much you can only fit one finger under the fender wells (both front and back). I have cusco Zero-2s and I have set the fronts to 3 and rears to 2 (out of 5).
I'll get a pic up once I clean my car
Old Jan 11, 2008 | 04:06 PM
Al_s14's Avatar
Al_s14
thanks for the input guys. i plan on ordering pretty soon ill let you know how it goes.!!
btw this is what they are going on . 18x9.5 g-games 2 piece
Old Jan 11, 2008 | 07:44 PM
JETPILOT's Avatar
JETPILOT
by the way i am looking in to Falken Fk452 which are at 139ea
all input appreciated thanks!
275/35/18 will rub on the fronts with a 9.5" wide wheel with a 20 offset. No question.
I have a 275/30/19 on a 9" wheel with a 25 offset and they rub a little.
JET
Old Mar 15, 2008 | 08:27 PM
3m wol8's Avatar
3m wol8
Originally Posted by SOLO-350Z
It works just fine. As long as the size of the tire ratio is the same, VDC won't complain. Friend has 275 all around on 17s and it's a GT model, no problems with VDC.
don't mean to bump an older thread but what width rims is he running and what series tires? i've been trying to find 275/45/17's for rears to keep the tire size within spec but i'm having problems.. is he just running 275/40's all the way around? and is he lowered at all? also offset on rims? i was thinking a 17x9 +27 rim... thanks for any information you can get me
Old Mar 15, 2008 | 09:01 PM
Cheezwiz's Avatar
Cheezwiz
Maybe he has a base model or is talking about 275/35-18 F and 275/40-18 R
ragtopz
Mar 28, 2004 07:31 AM
JJGALIA
Feb 26, 2004 03:40 AM
D_Nyholm
Oct 9, 2003 03:05 PM
3rdpower
Feb 22, 2003 10:59 PM
alex30327
Dec 24, 2002 06:47 AM
