Aggressive Wheels and Stretched Tires....Welcome
Old Mar 4, 2014 | 11:27 PM
  #23181
mrfobbyaccent's Avatar
mrfobbyaccent
I read on zilvia that you have a 6in lip. a 6in. lip with an lxz will definitely not have the offset of -16. It is to weak. Looking at the face of your wheel it seems to me that you have the concave faces and from personal experience, My buddy who had the same set of wheels with a 6in lip had the offset of 18x12-25ish ie 6in inner barrel 6in outter lip. Now assuming that you have the concave faces, your off set for your 18x11.5's with a 5.5 barrel and a 6in lip should be the realm of -34ishh, don't quote me on any of this though lol
You can also run a 235-40 tire that may solve your issue, or like what the other's said, pull your fenders. I would personally run the smaller tire. I made the mistake of pulling fenders
Old Mar 4, 2014 | 11:53 PM
  #23182
KingBaby's Avatar
KingBaby
Hardest Setting
the look on that kids face is priceless...
picture stolen
Old Mar 5, 2014 | 07:43 AM
  #23183
albertsZ's Avatar
albertsZ
Originally Posted by Tomci08
personally i would pull the rears more but thats just me.
I might go at it a bit more, but it's seems to get sloppier and sloppier as I go, even when I use more heat and go slower with the roller.
Originally Posted by QuintonC
^ +1
Try pulling the rears more before you go switching up tire sizes without knowing your wheel size. Just remember that easy does it, plenty of heat and patience yields the best results.
Yeah I will try and go at it again, but I am not liking the results.
Originally Posted by shaddy-z.
There is just no way in hell your offset is right. But they look great. I'm running 18x12 -12 with a 255/40 with 0 camber (I even have room for a larger spacer since I raised the car a tad) . What I would do is heat up your fender real nice, jack the car up and put a phone book or a thinner phone book type book in the fender and let the jack down slowly. That's what I did, you won't get waves and the fender will just form to the tire. You could also roll it slowly if ya want either way works.
Thank you for your feedback and suggestion. I have done the phone book roll a bit and I like it better than using the actually roller to pull. I just need a thicker one now.
I'm debating either 235/40 or 245/35... I should probably go with a 235/40 since it seems to be the more common tire size. Thank you again for the input, I'm assuming my wheel is somewhere in the -20 to -30 offset range.
I will just leave another photo here, to keep this thread on track.
Old Mar 6, 2014 | 12:19 AM
  #23184
mrfobbyaccent
Don't get a 245-35 it's really expensive, and it won't fit, i've tried lol
Old Mar 6, 2014 | 06:04 AM
  #23185
albertsZ's Avatar
albertsZ
So I finally did my homework and was able to calculate my wheel offset and alla that. Turns out the guy who sold me the wheels was completely clueless about his wheel size and offset after he got them relipped...
First I measured the rear barrel and got 6 inches.
and then here I measured front barrel and got 6inches...
and then I do an overall measurement and get 12.5.... but I read that you are supposed to measure from where the tire bead sits... so you take away approx about an inch so effectively 11.5
Then I did some more measuring and measured the hub to the top end of the barrel and got 5.5 inches, which corresponds 139.7mm. This is also called backspacing.
To measure offset (at least from my sources) you take the wheel width (11.5in=292.1) then divide it by 2. 292.1mm/2 = 146.05mm. This measurement is where 0 offset is located. Then you take this measurement and subtract it from the backspacing measurement. 139.7(backspacing) - 146.05 (0 offset location) = -6?
So my wheel is actually 18x11.5 -6... can anyone confirm my results? I've been going back and fourth at this all morning. Would mos def appreciate it.
I hope that is helpful to anyone reading this.
Old Mar 6, 2014 | 01:04 PM
  #23186
QuintonC's Avatar
QuintonC
-6 sounds right.. I was at -5 for a while and rocked like -7 camber though so it is very possible. And that was on an 11 with 255/35/19. My advice for you if you don't want to do body work is to get them re-barrelled. Or sell them to me :P
Old Mar 7, 2014 | 04:18 PM
  #23187
DeeSan's Avatar
DeeSan
nope totally wrong. You took your backspacing measure based on width of 12.5 so that 292.1 you used should be ~317.5.
If you knew the face type and disk type, it would be pretty easy to tell their exact offset. http://kranze.jp/english/lxz.html check the specs they are different for FR and FF faces.
In any case, those are definitely more aggressive than 18x11.5 -6.
Wheel market problems are :
1- 95% of ppl don't have a clue how offsets actually work, so they buy/trade/sell without knowing what's really in the deal.
2- most ppl don't even know there are different disk types made. Fact is how often do you see a FS ad with disk type listed? Almost never, yet it's VERY important.
3- ppl lie and make up random offsets all the time. Take any wheels, let's say equips for instance, I've seen ppl refer to them as 18x12 -1 -2 -3 -4 -5 -6- 7- 8- 9- 10, while the truth is only 12 -4 (R disk) and -5 (O disk) were in the offset I just listed as example.
as a reference.. my car with 18x12-5 running -3* camber and they can easily tuck inside under full compression. My fenders are obviously pulled but nothing crazy like some of the other guys in here.
Old Mar 8, 2014 | 11:39 AM
  #23188
Big_C's Avatar
Big_C
Close up's of the powdercoat
Old Mar 9, 2014 | 08:47 AM
  #23189
DVSIR911's Avatar
DVSIR911
Default Fender pulling max
Can someone help me out with a question about pulling? In your guys experience, how much room are you getting with max pull on the front and rear of the Z? If I ran for example a 19x10.5 +12 all around, what size spacer could I run to be flush? Thanks. I was thinking in the -20's.
Old Mar 9, 2014 | 09:03 AM
  #23190
terrasmak's Avatar
What do you consider flush? Do you want the super stretched tire crap with -10 degrees of camber , proper fitting tires with proper camber , or somewhere in the middle.
Old Mar 9, 2014 | 09:24 AM
  #23191
-miltdoggie-'s Avatar
-miltdoggie-
Why pull with a small wheel and small tire?
Old Mar 9, 2014 | 10:14 AM
  #23192
DCJodon's Avatar
DCJodon
A pull is probably not necessary with those specs.
Old Mar 9, 2014 | 06:44 PM
  #23193
DVSIR911's Avatar
DVSIR911
Ok so a 19x10.5 -26 on the rear doesn't need a pull?
Old Mar 9, 2014 | 06:49 PM
  #23194
CJM's Avatar
CJM
What tire do you want to run?
Old Mar 9, 2014 | 06:51 PM
  #23195
DVSIR911's Avatar
DVSIR911
Originally Posted by cjm
what tire do you want to run?
235/35
Old Mar 10, 2014 | 01:53 AM
  #23196
terrasmak's Avatar
Just throw a 245/40 on the rear and run with about -1.5 rear camber and a 10 mm spacer , you will have a nice poke and only need a normal roll. The a 245/35 front no spacer, set camber to make it sit flush with the ride height you choose.
Old Mar 10, 2014 | 09:31 AM
  #23197
DCJodon's Avatar
DCJodon
Not sure why you would want to run such a low offset on a somewhat narrow wheel. Ditch the spacers and get something a little wider.
Old Mar 10, 2014 | 02:16 PM
  #23198
DVSIR911's Avatar
DVSIR911
Just forget I asked.
Old Mar 10, 2014 | 08:06 PM
  #23199
kennyy's Avatar
kennyy
hi
Old Mar 11, 2014 | 06:10 AM
  #23200
AmateuRN's Avatar
AmateuRN
^^ Look like you cut out a picture of a Z, taped it to your computer screen, took a picture, then uploaded it to the site.
