Aggressive Wheels and Stretched Tires....Welcome
Old Feb 16, 2015 | 11:33 AM
  #23521
Royal_T's Avatar
Royal_T
A little tease...Got my tires finally mounted up. Will post pics once my alignment is done.. to much camber in the rear and toe is missed up..Need my 0 camber out back... Feels so good to be back..
Specs:
18x9.5 -22 235/40
18x12 -10 275/35
Old Feb 16, 2015 | 12:19 PM
  #23522
Lexo350z's Avatar
Lexo350z
ok so I've got one question for you guys. if I want to work on a wheel that has a tire mounted on it and I just want to work on the faces to remove them off the wheel and not dismount the tires at all, is that possible to do by just removing all the air from it? and if so is there a possibility that the seal in the barrel might get loose at all? any feedback would be appreciated. thanks.
Old Feb 16, 2015 | 12:50 PM
  #23523
driftsucky's Avatar
driftsucky
If you let all of the air out of the tire, there is a possibility that you will loosen the bead. But, it's not very likely. If you're going that route, it isn't really neccessary to let the air out at all. It doesn't really seem safe to keep the tire on there as you're disassembling a wheel, but logistically, it should cause you know issue.
Old Feb 16, 2015 | 01:03 PM
  #23524
che69velle's Avatar
che69velle
Need to clean them
Old Feb 16, 2015 | 01:14 PM
  #23525
SR71's Avatar
SR71
Lead Super Moderator
When taking apart wheels it is always recommended to demount the tires first. Once the face/center is removed the barrel will lose a lot of its structural integrity and can deform form the tire still being mounted, no tire is perfectly found and put an enormous amount of force on the barrel in the bead area. Another step you should take is to mark each center as to which barrel it came from and be sure to pair them back up when you reassemble them. Multi-piece wheels don't get just get bolted together and shipped out at the factory, once they are assembled they go through a "truing process" that rounds them out to min requirements. So buy taking them apart and mixing them up you can disrupt their roundness and can end up with wheels that will require more weight to balance and may not even roll true again with out being straightened/refinished.
Old Feb 16, 2015 | 01:15 PM
  #23526
Lexo350z's Avatar
Lexo350z
well I just want to remove the faces and rework them then place them back onto the wheel but I really don't want to disassemble the whole wheel that's why I just want to see if its ok to remove all the air without disturbing the seal..??
Old Feb 16, 2015 | 02:09 PM
  #23527
taobon's Avatar
taobon
anyone knownwhos make 265/30/19 ? any other brand that stretch good ?
Old Feb 17, 2015 | 05:17 AM
  #23528
driftsucky's Avatar
driftsucky
Here's a list of tire comapnies that make 265/30/19
Alliance Tire Company
Apollo Tyres
Apollo Vredestein B.V.
Avon Rubber
B
Balkrishna industries
Barum (company)
Belshina
Bridgestone
C
Casumina
Cheng Shin Rubber
Clément Tyres
Coker Tire
Continental AG
Cooper Tire & Rubber Company
D
Daehan Tire
Danang Rubber Company
DMACK
Dominion Tire Plant
Double Coin
Dunlop Rubber
Dunlop Tyres
E
Elastorsa
Englebert (tyre manufacturer)
F
Falken Tire
F cont.
Federal Corporation
Firestone Tire and Rubber Company
Fullrun Tyre
G
General Tire
General Tyre Pakistan
Gislaved (tires)
Giti Tire
Goldstone Tires
Goodyear Dunlop Sava Tires
Goodyear Tire and Rubber Company
H
Hangzhou Zhongce Rubber Company
Hankook Tire
Hoosier Racing Tire
Hutchinson SA
J
JK Tyre
K
The Kelly Springfield Tire Company
Kenda Rubber Industrial Company
Kumho Tires
L
List of aircraft tire companies
List of tire companies
M
Matador (company)
Metzeler
Michelin
N
Nankang Rubber Tire
Nexen Tire
N cont.
Nokian Tyres
O
Omni United
P
Palmer Cord Tyres
Pirelli
S
Saovang Rubber Company
G. S. Sareen
Schwalbe (tire manufacturer)
Seiberling Rubber Company
Servis Tyres
Slime (brand)
Sonar Tire
Starco
Stomil Olsztyn (company)
Sumitomo Rubber Industries
T
Thistle Manufacturing Company
Titan Tire Corporation
Tornel
Toyo Tire & Rubber Company
Trelleborg AB
Triangle Group
U
United States Rubber Company
V
Vittoria S.p.A.
Vogue Tyre
Y
Yazd Tire
Yokohama Rubber Company
I may be missing a few, but that covers most of them.
Lexo350Z: once the air is let out, it takes like 2 seconds to dismount the tire. Again, I wouldn't ADVISE you to remove the face of the wheel and keep the tire mounted, but logistically, it is possible to do.
Old Feb 23, 2015 | 06:35 AM
  #23529
vex008's Avatar
vex008
Old Feb 24, 2015 | 01:57 AM
  #23530
KingBaby's Avatar
KingBaby
Hardest Setting
Tough...
Old Feb 24, 2015 | 05:45 AM
  #23531
vex008's Avatar
vex008
Yokohama SDrive have the size you specified. 255/35/19 just went on the rears and it stretched pretty good and easy. I imagine a 30 maybe a little tougher but all in all I like the SDrives, hope they last as long as the Falken FK452s did - those were great but discontinued.
Old Feb 24, 2015 | 08:05 AM
  #23532
driftsucky's Avatar
driftsucky
Originally Posted by vex008
This is everything.
Old Feb 24, 2015 | 02:54 PM
  #23533
Vasque350Z's Avatar
Vasque350Z
I have 19x11 +15 all around 255/35 tires all the way around. The back sits perfect . However the front does not , it sits with no clearance so could I run more of stretched tire? Say 235/35 in front? Or would you recommend UCA? Or other options. Thanks.
Bunper is being changed so don't mind that lol
Old Feb 24, 2015 | 05:33 PM
  #23534
craig12895's Avatar
craig12895
You could run more of a stretched tire, or you could get your front fenders rolled over the tire
Old Feb 24, 2015 | 06:25 PM
  #23535
terrasmak's Avatar
You already have the cambergang stretch going, get the front arms and add extra camber
Old Feb 24, 2015 | 06:57 PM
  #23536
NoQuestionZ's Avatar
NoQuestionZ
What in the actual fkuc am I looking at here?!?! It looks like a stretched tire, but stretched to an inside bead rather than the lip 0.o As if the sidewall is caved in or something.
I take it the rear wheels(that sit perfect) are not on in this picture?
I have 18x10.5+15 with 275/35 on all 4 corners and while it's an inch smaller diameter, and .5 inch narrower, you shouldn't have THAT bad of fitment. If you are on coilovers, raise your car an inch to get the clearance.
here is a picture of my fitment lowered on Tanabe GF210s (until this weekend hopefully)
Attached Thumbnails Aggressive Wheels and Stretched Tires....Welcome-img_20141025_050255.jpg
Old Feb 25, 2015 | 08:42 AM
  #23537
A-Town-Z's Avatar
A-Town-Z
^^Who makes that hatch?! So clean
Old Feb 25, 2015 | 09:05 AM
  #23538
vex008's Avatar
vex008
Its an Asuka CF Hatch
Old Feb 25, 2015 | 12:42 PM
  #23539
driftsucky's Avatar
driftsucky
You've got a couple different ways to alleviate that. You could run about -2 camber up front. BOOM.
You could get a bit more stretch to your tire. BOOM
You could pull your fender about 15mm. BOOM.
Old Feb 26, 2015 | 06:09 AM
  #23540
Vasque350Z's Avatar
Vasque350Z
Thanks to all. I'll let ya know what happens lol
