Aggressive Wheels and Stretched Tires....Welcome
Old Jun 3, 2015 | 05:14 AM
  #23601
irishguy0224's Avatar
irishguy0224
it depends what you are going to try and accomplish. I don't even have camber arms or anything. I just let the natural camber do it's thing. With that, i was able to fit 18x12-2 in the rear with no issues at all, other than some fender work. My new set up will be 19x11-10 by the end of next week
Old Jun 3, 2015 | 01:26 PM
  #23602
Shmoke's Avatar
Shmoke
Well my concern is tire ware and toe adjustability. Am i able to adjust toe with just the spl rear toe links that i have and with no toe bolts?
I have some 18x10.5 all around wheels that iam planning to put on. I know the parts i ordered were abit over kill for my needs but i may go bigger nd wider wheels later down the road. I just want my suspension to be complete so i dont have to worry about it later, will i need toe bolts? If so which ones are you guys running?
Old Jun 3, 2015 | 03:33 PM
  #23603
jdmfetish's Avatar
jdmfetish
spl toe arms for a true set up is to adjust toe
but if you are worried about it , it would make sense to me to buy the toe bolts for $30 so when you are up on the alignment rack , better to have the bolts and not need them , them need and not have them
just don't open them so if you do not need them you can return them
spc are fine bolts
common sense
Old Jun 4, 2015 | 01:43 PM
  #23604
driftsucky's Avatar
driftsucky
@irishguy0224...you got some stuff and things going on? Must be time for some hangs soon!!!!
Old Jun 5, 2015 | 08:10 AM
  #23605
irishguy0224
you know where i live come on over
Old Jun 23, 2015 | 01:13 PM
  #23606
Ossion's Avatar
Ossion
Sup My350z fam!
I have lurked on these forums for quite some time and decided ton finally post some pics of my Z.
1st time posting pics hopefully the quality is there!
Old Jun 23, 2015 | 01:22 PM
  #23607
mr. sparco's Avatar
mr. sparco
Originally Posted by Ossion
Piping the exhaust into the cabin can't be good for your health.
Old Jun 23, 2015 | 05:51 PM
  #23608
travlee's Avatar
travlee
Master
cheap high yo
Old Jun 23, 2015 | 05:56 PM
  #23609
sofakiing's Avatar
sofakiing
the best color they made the Z in.
Old Jun 24, 2015 | 09:55 AM
  #23610
irishguy0224
Looks good man - i'm just over where wishing my UCA's would stop hitting my engine bay
Old Jun 24, 2015 | 11:08 AM
  #23611
QuintonC's Avatar
QuintonC
Which version UCA's do you have?
I had the old, bent frame designed ones. They needed warrantied out and I got the tubular ones. They haven't hit the engine bay yet. Though I have already cut out the hole for the top nut so they can be adjusted.
Old Jun 25, 2015 | 07:15 AM
  #23612
jdmfetish's Avatar
jdmfetish
Sup My350z fam!
*******got blunt***********
Old Jun 26, 2015 | 12:41 AM
  #23613
JoseValencia27's Avatar
JoseValencia27
So the SPC UCA's cheap?
Old Jun 27, 2015 | 03:11 PM
  #23614
MicVelo's Avatar
350Z/370Z Tech Moderator
No. There were problems with older ones under extreme lowering and camber correction. but the same blunt force trauma balljoint destruction can occur with any adjustable UCAs in those conditions. SPCs are ranked up near the top. Only ones my shop recommends and I totally trust Rob at ZCG.
Old Jul 1, 2015 | 12:18 PM
  #23615
irishguy0224
I have the new Kenetix UCA's, idk if they hit AS much as the OEM ones did, but hit on pretty much every single bump. I'm pretty low though
Old Jul 3, 2015 | 08:14 PM
  #23616
tm9293's Avatar
tm9293
finally got some good pics of this years set up
Old Jul 4, 2015 | 08:19 PM
  #23617
driftsucky's Avatar
driftsucky
Once I fix my tranny, I'll get some new pics up. Good to see some NY'ers in here.
Old Jul 6, 2015 | 11:42 AM
  #23618
pfregeolle's Avatar
pfregeolle
tm9293, what front camber arms do you have?
Old Jul 7, 2015 | 06:28 PM
  #23619
jlb's Avatar
jlb
Geneseo NY area here bud.
Old Jul 8, 2015 | 02:01 PM
  #23620
tm9293's Avatar
tm9293
Megan front uca's, maxxed out giving me around -5.5 in the front.. I did a lot of looking around and it seems they're one of the only brands that can give that much without any custom work
