Aggressive Wheels and Stretched Tires....Welcome
Old Jul 22, 2009 | 01:14 PM
  #3361
starve's Avatar
starve
Originally Posted by ohSIXz
starve,,,if u could do it again would u try a 19x11 +0 or stay with a 19x10 -25 in the rear? since its the same 'pokage' technically. or like a 11.5 +12?
My setup is equal to 19x11 -12 and 19x12 +0. According to the offset calculator. So I wouldn't want to run 11 +0
Old Jul 22, 2009 | 05:05 PM
  #3362
Busted*Shox's Avatar
Busted*Shox
yay
Old Jul 22, 2009 | 06:13 PM
  #3363
NYC03Alti's Avatar
NYC03Alti
Actually, no. starve is right.
Old Jul 22, 2009 | 06:45 PM
  #3364
Busted*Shox
gay
Old Jul 22, 2009 | 06:50 PM
  #3365
jdmrwd's Avatar
jdmrwd
Hope this will help
http://www.rims-n-tires.com/rt_specs.jsp
Old Jul 22, 2009 | 06:57 PM
  #3366
Thermal1's Avatar
Thermal1
Originally Posted by Busted*Shox
So let me get this straight...25.4 mm does not equal an inch? His rears are 19x10 -25...offset is measured in millimeters
You are forgetting the other side of the wheel. "Adding" and inch "adds" width to both sides of the wheel so to speak. So you only subtract half an inch (or 12.7mm) from the offset number.
Old Jul 22, 2009 | 07:11 PM
  #3367
starve's Avatar
starve
Not trying to rain on your parade or anything bro but your current setup is equivalent to 19x11 +0...some of these offset calculators are bs
Good point, but let's take this into account. There's a 1 inch difference, so let's split that in half. And extend it outwards past the center line. So u would subtract 13 from -25. And that gives us -12. So what about the other 13 mils? Its going inwards towards the strut on the other side of the center line. I believe this is the thinking behind the offset calculators.
Old Jul 22, 2009 | 07:52 PM
  #3368
spoolngst's Avatar
spoolngst
smart one.... offset guru starve ftw.
Old Jul 22, 2009 | 08:05 PM
  #3369
starve's Avatar
starve
Originally Posted by spoolngst
that answer will be answer within a couple of weeks hopefully, starve will show and tell when its ready..
its a little teaser of my G after i rerolled but ended up flaring the rear
im on df210 right now just waiting to pick up some coilover, pic is taken on a incline in my drive way just to see how it will sit once i dump it
20x11 -19 255/35
No one see's the barbaric nature of this setup?
Old Jul 22, 2009 | 09:17 PM
  #3370
alltech_magoo's Avatar
alltech_magoo
^^ shoot Mot G is gonna be gangsta. Cant wait for him to acheive what he's going for.
Old Jul 22, 2009 | 09:25 PM
  #3371
hatchboi's Avatar
hatchboi
Originally Posted by starve
Let's just say my lip is good from a far, but far from a good. It scrapes under normal braking, and uneven roads.
man after i drop my car some more and finally got my 15mm spacer on, i total feel what starve said. same situation with my lips and also scraping on uneven roads. have any more picture from the meet starve?
20x11 -19 255/35
your fender flare looks good man. curious if you driven the car up a driveway and let the rears compress inside the fenders yet? did your lip scrape on the inside of the fender? my 20x11 -7 look kinda like your setup before i flared it and the lip scraped all up in the fender. i just got my flares done also but had to remove the inside of the fender so the fenders would flare more because i had my fenders cut before. gotta bring it to the body shop to clean it up and repaint it.
Old Jul 22, 2009 | 10:30 PM
  #3372
spoolngst's Avatar
spoolngst
hatchboi, thanks for bring that to my attention but i havent reach that point yet cause im still on springs but once i get some coilover and lower it then i'll let you know. At this point im still trying to clear my 255 35 where the rear quarter and bumper meets and doing it without the use of camber arm or buying a smaller set of tire but i think camber arm might be a big help. I'll post up more pic within the next couple week or when ever i think i have good updates.
hatchboi do you have any pic of your setup? if you do but dont want to post cause it still under construction do you mind PM'n me some i want to get an idea of your setup since you are running something similar
Old Jul 22, 2009 | 10:45 PM
  #3373
THE_SCHROED's Avatar
THE_SCHROED
Default Enkei RPF1 18x10.5+15
Old Jul 22, 2009 | 11:25 PM
  #3374
ryanmac516's Avatar
ryanmac516
i like boobies
i am currently running a 19x11+5 front and 19x12+12 rear currently
Old Jul 23, 2009 | 04:55 AM
  #3375
spoolngst's Avatar
spoolngst
you are running 10mm wider front fender right???
Old Jul 23, 2009 | 08:14 AM
  #3376
andrew16639's Avatar
andrew16639
Exclamation
Originally Posted by 10 TIL 4
Currently 245/35/20 and 275/30/20. Minor stretch.
Whats the size of your rims and Offset?
How much inchs lowered and camber spec.
Old Jul 23, 2009 | 12:28 PM
  #3377
fatboy.yoshi's Avatar
fatboy.yoshi
Originally Posted by hatchboi
...have any more picture from the meet starve?
moar pics....linked to our team site
http://www.theteamikon.com/forums/sh...9739#post69739
Old Jul 23, 2009 | 12:39 PM
  #3378
Big_C's Avatar
Big_C
Thanks to Logan @ Work Wheels for throwin up pics of my Z on their new blog page! Its the blue Z a lil ways down....
http://www.iputinwork.com/?paged=2
Old Jul 23, 2009 | 12:43 PM
  #3379
Darkside Eng's Avatar
Darkside Eng
Former Vendor
Some crazy cars in this thread! Nice work guys
Old Jul 23, 2009 | 05:48 PM
  #3380
ryanmac516's Avatar
ryanmac516
i like boobies
yea i am but with the lip inside the front fenders i probly had less room then stock. i was rubbing the inside lip of the wider fenders but i have since trimmed out most of the lip i dont rub anymore. i do want to trim the last 10mm of the lip off and try to take some of the camber out of the front. i am currently at like 3.5d degrees of camber in the front and like 3 in the rear. i want to try to get to like 3 front and rear.
