Aggressive Wheels and Stretched Tires....Welcome
Old Jul 28, 2009 | 05:04 PM
  #3441
andrew16639's Avatar
andrew16639
Question
Originally Posted by BarefootRacer
My boy Busted shox car..
Whats the specs on wheels, tires, and camber?
Old Jul 28, 2009 | 05:13 PM
  #3442
andrew16639
Question
Originally Posted by MrToeknee
Somebody said Tony? Lol, been a while since we all got together.
Old Jul 28, 2009 | 07:11 PM
  #3443
Busted*Shox's Avatar
Busted*Shox
Some more pics from the import alliance meet we had over the weekend...wheel and tires specs are 18x10 +4 18x12 +4 225/40 275/35
Old Jul 28, 2009 | 08:07 PM
  #3444
resauto's Avatar
resauto
Originally Posted by naggar
So it looks like robzone over on g35 driver is trying something different and running negative offsets but with a 305 tire out back and 255 up front. I must admit I like it and it makes me wanna try something new.
nope....Im running a 315 in back ....im resauto on these forums
Old Jul 28, 2009 | 09:09 PM
  #3445
theintimmydator's Avatar
theintimmydator
:ico n28:
Old Jul 28, 2009 | 09:29 PM
  #3446
tonyrd1's Avatar
tonyrd1
Sure.
Front=18x10.5 15mm offset with 265/35/18
Rear=18x10.5 15mm with 20mm spacers (-5 offset) with 265/35/18
Thanks a lot, did you roll and pull your rear fender?
Old Jul 28, 2009 | 09:32 PM
  #3447
MrToeknee's Avatar
MrToeknee
275/30/20x10.5 +0 @ -3.7
Old Jul 29, 2009 | 05:29 AM
  #3448
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
SICK looking ls you got there man
Old Jul 29, 2009 | 07:31 AM
  #3449
2k6-z33's Avatar
2k6-z33
Old Jul 29, 2009 | 09:02 AM
  #3450
redlude97's Avatar
redlude97
Originally Posted by calin
Hey guys!! I got my Work VS-XX's not too long ago and they're not as aggressive looking as I thought they would be. So I come to you guys for help
Here are my specs:
wheels are 19x9.5 +15 and 19x11 +23
and tires are 245/35/19 and 275/35/19 Vredestein Sessanta's
I need some opinions on what would make these wheels look better.
Option 1: get 10mm spacers in the rear and 5mm in the front so the tire is more flush with the fender
Option2: get coilovers and drop it about another half inch or so to close that gap. I'm currently dropped on Eibach Sportline springs and have my fenders rolled. This is my DD so I don't want to go TOO low, but I wouldn't mind going a bit lower.
Let me know what you guys think would look better. Thanks!!
If you want something remotely worthy for this thread, you need 20mm spacers in the rear and 15mm spacers in the front. 10mm spacers in the rear is not aggressive, I've fit a wheel with almost the same offset and with nonstretched 285/35/19 rear easily.
Old Jul 29, 2009 | 07:23 PM
  #3451
Royal_T's Avatar
Royal_T
Daaammmmnnn Shox,,, car is lookn good my friend. I wonder if 19x12 +4 with 275 will fit... but lookn good Shox wish I was near so I could check it out...
Old Jul 29, 2009 | 07:34 PM
  #3452
resauto's Avatar
resauto
MAKE IT FIT! If i can get 315 to fit on 11 -3 ......then that 275 should fit...of course i had to RE-flare my fenders for the 4th time IT CAN BE DONE if your wiling to push the limits.
Old Jul 29, 2009 | 08:03 PM
  #3453
spoolngst's Avatar
spoolngst
if you are willing to you can make it work, where im at right now i can pull 19x12 in the high negative single digit offset cause my 20x11 -19 with 255 35 on rub on incline an bump on road
Old Jul 29, 2009 | 09:00 PM
  #3454
Busted*Shox
I went with a 18x12 because I wanted more tire with a good stretch in the rear...as you can see I have credit card clearance between the fender/tire and its about as low as it can go to be driveable. My front mud flaps will actually touch the ground if I put them on I think anything over a 275 in the back is overkill if your trying to stay flush or have a lil poke. You will have to camber the hell out of the rear or attempt to pull your fenders for anything more than that but different strokes for different folks.
Old Jul 29, 2009 | 09:14 PM
  #3455
ryanmac516's Avatar
ryanmac516
i like boobies
im running a 19x12 with a 285/30/19 with 3 degrees of camber in the rear, but my offset is only +12
Old Jul 29, 2009 | 10:21 PM
  #3456
Royal_T's Avatar
Royal_T
resauto and spoolngst you'll got a point,, ok time to look in to fitting some 295 on the rear 19x12 -et here I come
hey resauto what size is your front tires?? and do you have full lock?
Old Jul 30, 2009 | 03:01 AM
  #3457
spoolngst's Avatar
spoolngst
thats right different stroke for different folks, some like slam on 18s an some like it dump on 20s, some like it flush and some like it poke, fat tire and stretch tire. gotta mix it up. it'll be boring to see the same new setup every day, someone gotta be different and do something new to keep more it interesting.
but you're running 19s so that extra inch makes up the different from running 18s, you get less camber for clearance from size of your wheel unless you run camber arm
Old Jul 30, 2009 | 03:10 PM
  #3458
resauto's Avatar
resauto
255 30 continental! I can turn the wheels full both ways! 315 25 rears!
Old Jul 31, 2009 | 01:24 AM
  #3459
solidsnake's Avatar
solidsnake
Better angle. I might lower my coils just a tad bit more.
That looks hella clean
Old Jul 31, 2009 | 03:50 AM
  #3460
z33allme's Avatar
z33allme
Let me try this one more time?
Attached Thumbnails Aggressive Wheels and Stretched Tires....Welcome-photo.jpg   Aggressive Wheels and Stretched Tires....Welcome-photo-1.jpg
