Aggressive Wheels and Stretched Tires....Welcome
Old Jul 23, 2009 | 07:02 PM
  #3381
Big_C's Avatar
Big_C
Originally Posted by starve
No bags for me, caveman stance all the way!!! Let's just say my lip is good from a far, but far from a good. It scrapes under normal braking, and uneven roads.
My rears are the same way. My 20x11 -5 hit the inner fender lip and are scratched up after less than a month of owning the wheels. I'm not that great with a fender roller so I tried pulling the fenders in the rear a lil but they just wrinkled a little bit and didn't turn out even (just like on my previous s13). At this point I don't really care anymore lol, the look is worth it. Luckily the scratches can be sanded down and buffed out and you'd never know but it still kinda sucks. I kinda want different wheels already anyways, so it doesn't bother me that much.
Originally Posted by spoolngst
that answer will be answer within a couple of weeks hopefully, starve will show and tell when its ready..
its a little teaser of my G after i rerolled but ended up flaring the rear
im on df210 right now just waiting to pick up some coilover, pic is taken on a incline in my drive way just to see how it will sit once i dump it
20x11 -19 255/35
hatchboi, thanks for bring that to my attention but i havent reach that point yet cause im still on springs but once i get some coilover and lower it then i'll let you know. At this point im still trying to clear my 255 35 where the rear quarter and bumper meets and doing it without the use of camber arm or buying a smaller set of tire but i think camber arm might be a big help. I'll post up more pic within the next couple week or when ever i think i have good updates.
hatchboi do you have any pic of your setup? if you do but dont want to post cause it still under construction do you mind PM'n me some i want to get an idea of your setup since you are running something similar
I tried 255.35.20 at first on my 20x11 -5 and it didn't clear for **** on my Z. Maybe the G has more room but my tire would have for sure hit the part where the bumper and fender meet, no question about it. I switched to a 255.30.20 and problem solved, WAY more clearance. 35 series in the rear of our cars with aggressive 20s aint gonna work in my opinion. Your fenders have a nice flair so I dunno if thats enough to clear when you try to get in and out of driveways or going into a shopping center that has a steep incline. My car when compressing one corner in those situations hits the lip of the wheel even with pretty damn stiff coilovers. I even tried running up to -6 degrees camber in the rear and the lip would still hit my fenders. 20s with negative offsets aint no joke, they are much harder to get to fit without any issues than 19s. I am running rear camber and toe arms on my Z and its currently sitting at -4.6 degrees camber driver rear and -4.9 degrees pass rear. The one solution I did find to avoid hitting the rear lip on a steep incline is to go in perfectly straight instead of at an angle. The 20s give good ground clearance so I don't scrape my exhaust or anything which is nice.
Old Jul 23, 2009 | 07:44 PM
  #3382
spoolngst's Avatar
spoolngst
Originally Posted by ryanmac516
yea i am but with the lip inside the front fenders i probly had less room then stock. i was rubbing the inside lip of the wider fenders but i have since trimmed out most of the lip i dont rub anymore. i do want to trim the last 10mm of the lip off and try to take some of the camber out of the front. i am currently at like 3.5d degrees of camber in the front and like 3 in the rear. i want to try to get to like 3 front and rear.
you should do what i did on my aftermarket front fender just shave the whole entire lip off and you will gaiin plenty of clearance. Thats what i had to do on my eclipse cause i didnt have any front camber so i trim everything off and clear bout 10mm just enough to where i can turn my wheel with out hitting the fender at my ride height
Old Jul 24, 2009 | 05:31 AM
  #3383
10 TIL 4's Avatar
10 TIL 4
Originally Posted by andrew16639
Whats the size of your rims and Offset?
How much inchs lowered and camber spec.
245/30's were put on yesterday so now I'm 245/30/20 up front and 275/30/20 out back. The wheels are 20x9.5 +13 and 20x11 +6. I'm on Function & Form Type II coilovers, don't know how much I'm lowered.
The 30's up front definitely gave me room to slam the front a little more however.
Old Jul 24, 2009 | 06:18 AM
  #3384
z33allme's Avatar
z33allme
Keep the pics coming..
Old Jul 24, 2009 | 09:20 AM
  #3385
johzp's Avatar
johzp
^ you need to post pics of your car!
Old Jul 24, 2009 | 03:26 PM
  #3386
Nevaland90's Avatar
Nevaland90
a few pics a friend of mine snapped at a drift event...
fronts are heat cycled to death and rears are chunking/suicide bald. Thinking about what size tires to run on them for a time trail next month with out having to raise the car, ill keep you guys posted.
Old Jul 24, 2009 | 03:39 PM
  #3387
finalforce's Avatar
finalforce
It's nothing overboard, but here's my 5.25" rear lip
Old Jul 24, 2009 | 07:17 PM
  #3388
darkzschneider's Avatar
darkzschneider
nice ^
Ok ok. I finally ordered my new wheels so i can join the aggressive wheel club!
Old Jul 25, 2009 | 12:43 AM
  #3389
hatchboi's Avatar
hatchboi
power to you if you can get them to work without camber arms but i got pretty much everything i needed to adjust camber and toe to make life more easier for me (but that wasnt the case, sh*t was still a pain). 245/35 worked for me but naggar went with 255/30 and worked for him. im not worried about being judge with my retarded looking pull (cut the fender when i didnt know nothing bout fitment and lost the fenders structure so that why it looks like that) and cut tires so i took some pictures today to help you out while i was putting my front bumper, side skirts and rear bumper on. old cut tires will be replace, rear fenders will be fixed and repainted (might even repaint the car, duno yet), and car will be washed. i highly suggest if any of you guys have a lot of camber as i do and want your toe back to specs, get the battle version toe arm that replaces the spring bucket. i am currently running -5.5 camber in the back and my toe is all the way back into specs with the help of those battle version toe arms.
this pictures was when i was rushing to get to the hooters meet down here and i didnt have time to adjust the camber arms so that why my tires are cut up from the fenders. the car is lower in the rear a little more now but you can see how much it pokes before the pull.
Originally Posted by fatboy.yoshi
moar pics....linked to our team site
http://www.theteamikon.com/forums/sh...9739#post69739
thanks fatboy, i see rob took a drive down there to chill. man must be fun when yall drive around together and everyone look at your crew like wtf is wrong with there wheels...HA! i get that a lot around here and thats only driving by myself, just imagine a large crew with tite wheel fitment cruising around...FUN!
Old Jul 25, 2009 | 10:10 AM
  #3390
Highstar's Avatar
Highstar
heres my 04 g35 sedan this was just a test fit ill be running a 15mm spacer. but before spacer specs are 19x10+24(only have the rears right now)
Old Jul 25, 2009 | 10:02 PM
  #3391
NA&CH's Avatar
NA&CH
/\ Nice kicks Any distance shots?
Chris
Old Jul 26, 2009 | 02:02 AM
  #3392
n00bis's Avatar
n00bis
Thought u guys might enjoy this (sorry for the shitty phone pics) but this could be one of the best s15s in Aus. It has the JUN catalogue pumped into it including the JUN 2.2l stroker kit. Sorry dont no much on the specs of the wheels but its a pretty rude offset considering its full widebody.
And a lil look see under the bonnet mmmmmm
Old Jul 26, 2009 | 07:35 AM
  #3393
andrew16639's Avatar
andrew16639
Exclamation
Whats the size of the wheels and tires,also include offset.
Old Jul 26, 2009 | 09:12 AM
  #3394
ryanmac516's Avatar
ryanmac516
i like boobies
hey get your car cleaned up and all we need is you me and tony to get together. that would make a pretty good photoshoot
Old Jul 26, 2009 | 12:55 PM
  #3395
2k6-z33's Avatar
2k6-z33
SICK!
Old Jul 26, 2009 | 03:47 PM
  #3396
Nevaland90's Avatar
Nevaland90
19x10/11 255/30 & 255/35
that S15 also looks like its running little to no camber
Old Jul 26, 2009 | 11:31 PM
  #3397
hatchboi's Avatar
hatchboi
me and tony was talking about getting a photoshoot together a few weeks ago with gerb (that guy that did his current shot). we're both waiting on our bbk, so after that we'll be ready. we'll try to pick a date so that all 3 of us can do it on the same day.
Old Jul 27, 2009 | 12:05 AM
  #3398
z2g's Avatar
z2g
man dont leave me out, my new rims come in tomorrow!!! Up late tonight are we?
Old Jul 27, 2009 | 12:07 AM
  #3399
z2g's Avatar
z2g
Oh and my boy in a g35 may be down for it too. We going to forged this weekend to get his car tuned
Old Jul 27, 2009 | 09:25 AM
  #3400
JonnyB504's Avatar
JonnyB504
No love for me huh?
Hate to ruin your pertty pictures with my less than adequate pokage lol
