Aggressive Wheels and Stretched Tires....Welcome
Old Mar 23, 2010 | 03:48 PM
  #7261
soclean's Avatar
soclean
Originally Posted by oneandonly5680
SoClean, car looks good bro, can't wait to see it after you lower somemore. What tire sizes did you end up going with?
Thanks! I ran 225/35/19 and 245/35/19.
Old Mar 23, 2010 | 03:52 PM
  #7262
soclean's Avatar
soclean
Originally Posted by Busted*Shox
I was going through some old pics reminiscing lol over last year pics...Royal what is up bro!! Car is def lookin proper as always!
Nice! Specs?
Old Mar 23, 2010 | 04:13 PM
  #7263
Busted*Shox's Avatar
Busted*Shox
Preciate it...your setup is gonna look dope as well when its all finished. This was my old setup...18x10 +4 18x12 +4 225/40 275/35
Old Mar 23, 2010 | 04:37 PM
  #7264
Royal_T's Avatar
Royal_T
^^ what up Busted*Shox,, What's new with you bro??
Old Mar 23, 2010 | 04:40 PM
  #7265
soclean's Avatar
soclean
Wow! Your setup looks pretty aggressive for being in the positive offsets.
Old Mar 23, 2010 | 04:41 PM
  #7266
iLLest_Z's Avatar
iLLest_Z
need a little advice ima go pick up some tires for my rims specs are 19x9.5+14 19x10.5-2 im looking for a decent stretch..what you guys think i should go with 245/35 255/35 225/35 245/35..??
Old Mar 23, 2010 | 05:01 PM
  #7267
Busted*Shox
Working my a$$ off trying to get my business going as a personal trainer and thats about it. I see you have def taken it to the next level and you found the extra pull needed to go wider and lower offsets in the rear Still have plans for the new z just waiting to hear back from Work if they are going to release new offsets if not im going with DPE's.
Old Mar 23, 2010 | 05:10 PM
  #7268
Fren-Z's Avatar
Fren-Z
[/QUOTE]
This is just too sick! Love it Eric and Edafe good job
Old Mar 23, 2010 | 06:01 PM
  #7269
rsoto20's Avatar
rsoto20
^ yeah that thing is slammed to the ground good wrk guys looks really good
Old Mar 23, 2010 | 07:10 PM
  #7270
jasabeast's Avatar
jasabeast
Before Coils on Tanabe GF210s
Work Emotion XD9s
After Stance Coils
Need to stretch tires more and go with a smaller sidewall, then im gonna run spacers on all corners
Old Mar 23, 2010 | 07:12 PM
  #7271
haeshik's Avatar
haeshik
after pic isn't showing
Old Mar 23, 2010 | 07:16 PM
  #7272
jasabeast's Avatar
jasabeast
refresh it i messed up the links from photobucket and i went back and fixed it.. they show up fine on my comp
Old Mar 23, 2010 | 07:23 PM
  #7273
haeshik's Avatar
haeshik
now ic, yes you need spacers and stretched tires to join this thread
Old Mar 23, 2010 | 07:31 PM
  #7274
jasabeast's Avatar
jasabeast
yeah im doing a 10mm all the way around until my Nittos are gone cause my toe is out of control lol... but then ill get new tires and run 20mm
Old Mar 23, 2010 | 07:57 PM
  #7275
iLLest_Z's Avatar
iLLest_Z
you guys should check out rimtuck.com for wheel help
Old Mar 23, 2010 | 08:10 PM
  #7276
jasabeast's Avatar
jasabeast
Cause that site helps alot
Old Mar 23, 2010 | 08:57 PM
  #7277
Thermal1's Avatar
Thermal1
Originally Posted by Royal_T
Okay everyone keeps asking me what I did. Well I pretty much got rid of the bucket spring and placed the spring on the coilover. This is the same method that the Stance True Coilover is done.. Here is a quick pic on how it looks before adjusting the collar...
We went for a test ride and it road like normal,, I will let you know how it goes over the week..
And here is another pic of fitment
That sounds like a really really bad idea. Im pretty sure those spring rates are VERY wrong for that application. Stance uses 11k progressive rear spring rates for their OEM type setup and 5k springs for their "true coilover" setup.
I can't tell from the pic, but whats holding the top and bottom in place? That bottom collar certainly isnt designed to hold a spring above it... If that coilover wasnt designed to be a true type, then you better be careful. Get the shorter rear springs and do it right.
I havent verified the above info, im just thinking out loud here...
Old Mar 23, 2010 | 09:39 PM
  #7278
Royal_T's Avatar
Royal_T
^^ Okay to clear some things up,, When you slam a car you want the highest spring rate Possible,, for the Z the best spring rate would be 14k/12k, so with that said the higher spring rate is a good thing.
Also you are talking about the helper collars, allot of people remove these with no problem, also the spring does not just hang there it is compressed up against the top of the strut.
My Stance Coilovers are setup just like this,, Thanks for your concern and I will let you know how it goes..
Old Mar 23, 2010 | 09:45 PM
  #7279
Fren-Z's Avatar
Fren-Z
As a friend of mine always says.......... "Don't be scared"
Old Mar 24, 2010 | 12:20 AM
  #7280
quakerroatmeal's Avatar
quakerroatmeal
I've always thought that if you have a gap inbetween the top of the spring to the body that means = no preload on the coilover = bad? I had my old car setup like that lowered it all the way with no preload and it drove like crap. Jsia's car is running BC's with the lower spring setup and it's quite low. Not as low as that though.
Edit: Here's a pic of the setup of Jsia's car with BC Coilovers and rear lower spring setup. The collars aren't even removed yet and it still has more room to go lower. Name:  24399_386164338205_676023205_525128.jpg
