Aggressive Wheels and Stretched Tires....Welcome
amg did you PM me asking about my wheel and suspension setup? or was that someone else with a similar name? my inbox was full and i selected delete all but i dont think i replied to the message..
anyway, if that was you:
stance coilovers
fabulous expands
F 19x10 +0
R 19x11 +0
-3 degrees camber
tires are falken fk-452's, 225/30 and 255/35
stance coilovers
fabulous expands
F 19x10 +0
R 19x11 +0
-3 degrees camber
hmm..
i have
Work Euroline
19 x 10 +17 Toyo T1R 245/35/19
19 x 11.5 +21 Toyo T1R 275/35/19
Greddy Type-S
I guess I need to run some spacers....... hmmm.......
but ur car looks dead-on to the fender mang. def. awesome set-up.
if you can post some more pictures of side shot, as well as fender shots, it would be nice.
btw, any rubbing issue?
i have
Work Euroline
Greddy Type-S
had a little bit of rubbing when i put the 255's on the rears at first but its gone now
i actually have about a fingers worth of clearance in the front and in the back. i can lower the front and rear more but have been too lazy to do it.
sorry, i dont have any shots of the fenders or from the side.
i think your wheels will look good. dont even think you'll need spacers. but how much camber are you looking to have?
probably right around -2.5 ish. I dont want to go under -3 tho.
my ex-335i had bad camber issue (-3.3) with KW V3's, so with 3000 miles or so, I had to go swap the tires sides.. which was shame...haha
I am a man of my word.....here's a couple snaps. The tire is about 3/8 of an inch (front and rear) tuck "under" the fender. The rear fenders have a custom cut and the fronts have a mild fender pull. Tire rubs in front and rear when I go up my driveway a little. Other than that, I never scraped on the road, nor do my tires rub the fenders (other than driveways; I take it by angles). My Veilside CF front lip is spotless, now that's good careful driving
+ best of all, my car rides smooth like stock...wohooo.
dam u these cars are fiyah...i need to hurry up n get my suspension...thanks cheanyoung for letting me drive the car sunday...hahah now i know i will have to get 215's for my fronts...
hmm..
i have
Work Euroline
Greddy Type-S
i have
Work Euroline
Greddy Type-S
finish installing coilover and wheels/tire set-up, had to roll the rear fender, and slightly on fronts,
I still want to put some spacers on the front, to make it more flush like rear tires. here are quick 2.0mp phone snap!
ty ty,
maybe try 15mm spacer? or more?
also, the front looks lower than rear,
somehow, that is the lowest i can go on the rear, with the greddy type-s coils.
but, fronts still have a inch more to go down... weird...
cant wait to get my new rims =) giggity.....
