Aggressive Wheels and Stretched Tires....Welcome
Correct Hatchboi. hammering did not work or look good because the quarter panel line was gone. Fitting the 305/30 tire was difficult because the hankooks are fat and has a round stretch but it was all I had to mount. the fender work will give me the opportunity to go more crazy in the future with the right stretch and camber/pull. Any progress on your car yet?? I want to see what it has been up to.
Good stuff bro,, cant wait to see them all finished up.. Man you guys are beating me to the punch with the 305s.. I am going to be stretching 305s too
on
what do you guys think of this setup for a 370Z?
The wheels I'm looking at are 20x10 -15 and 20x12 -10. The rears don't concern me because on my last setup i was running a 20x12+0 and -6.7 camber, it's the fronts. Do you think that's too aggressive even at lets say -5 or -6 camber? Tire sizes are 235/35/20 and 275/30/20
BTW, both the front and rear fenders are flared from the previous setup.
on
on
on
on
roll and pull... You should also eliminate the fender liner or cut them because you'll eventually remove the screw that hold it if your going that aggressive in the front or else you'll be rubbing like crazy.
i think the only person right now that can do 14s is cheanyoung. I tried and test fitted 19x14 -15 and there is no clearance inside and stuck out about 1.5inch before the camber started to set in from the fender, and my fender are pretty rolled/pulled/flared.
on
