Aggressive Wheels and Stretched Tires....Welcome
Old Jan 15, 2012 | 01:02 PM
  #18661
lowandsteezy's Avatar
lowandsteezy
Originally Posted by Kirbaaybaayy
the back is stiffer because it doesnt have an engine pushing it down??
I bought stiffer springs because my tire is so close to the fender that everytime i would go around a turn or hit bumps it would rub really bad. And yes my fenders are rolled. But now that i got stiffer rates in the rear the spring doesnt compress as much making the car set higher and my coilovers in the rear are maxxed. Stance told me i need helper springs but before paying 100$ i want to make sure it will atleast go another inch lower.
Old Jan 15, 2012 | 01:06 PM
  #18662
DeeSan's Avatar
DeeSan
well helper springs will def give you that inch your are looking for. That is if you have that space available between the two top lock ring and the bottom one.
Old Jan 15, 2012 | 01:09 PM
  #18663
DjTyfightr's Avatar
DjTyfightr
i dont think helper springs are what you need, arnt they just to keep your tires in contact with the road? With helper springs i think you would be even higher up. Not 100% but thats what i think
Old Jan 15, 2012 | 03:02 PM
  #18664
-miltdoggie-'s Avatar
-miltdoggie-
Old Jan 15, 2012 | 03:30 PM
  #18665
Max-G's Avatar
Max-G
yeah, they'd make him higher if anything.
lowandsteezy- have you removed collars? or sagged the springs? also, after a couple months of driving the springs will break in and the car will sit a bit lower.
Old Jan 15, 2012 | 03:56 PM
  #18666
lowandsteezy
Sagging the spring is not good. I would think helper springs would raise it also but not what stance says. Also i have threads showing to go lower but the spring is so much stiffer and there really is very much settling. I have about 1/4inch left of threads with out removing collars. Stance said i would have to remove the collars and install the helper spring and it will give me the "initial droop" that i need they said. I barely need an inch lower but im on 18's and slammed.
Old Jan 15, 2012 | 05:37 PM
  #18667
Max-G's Avatar
Max-G
i understand what stance is trying to tell you to do (under the weight of the car the helper springs are usually almost fully compressed), but i don't think it will get you as low as you need to go. just sag the springs. i've been driving on sagged springs for 7 years and never had any issues with stance, fortune, bc, cusco, or jic.
Old Jan 15, 2012 | 05:38 PM
  #18668
DeeSan's Avatar
DeeSan
Dunno wtf ppl are saying in here but they're wrong. Helper springs do not make your car higher, they let you go lower on the threads without having the spring loose and at the same time giving you additional drop. However, idunno how thick stance's lock rings are, all 3 removed should give you close to an inch 1/4 + you said you still had 1/4 left. Now all there's left to find out is how thick the helper spring is fully compressed. Since you don't have much space to play with HS might not be able to give you an inch. In the end you will probably need HS + shorter springs or send them back to get shorter struts
Get the HS, remove lock rings and you are set.
Old Jan 15, 2012 | 07:52 PM
  #18669
Max-G's Avatar
Max-G
i had some 12/10k stance gr+ pro's on my s13 and when on the ground the helper springs were about 3/4 compressed and were 1"+ tall. looked like they would be maybe 1/2" fully compressed.
a collar is about 1/4"-1/3" so 2 removed with the gap = 3/4"-11/12" lower. he said that he wanted to go almose 1" lower. might be happy at 11/12" lower, but that definitely wouldn't give any space for a helper spring.
if he had 2" to spare then the helper springs would be the way to go...
also, helper springs are basically the same as sagging a spring since they "droop" at static height.
Old Jan 15, 2012 | 07:56 PM
  #18670
512_Z's Avatar
512_Z
Shorter Srpings worked for me and all this DEESAN said is true
Old Jan 15, 2012 | 09:10 PM
  #18671
lowandsteezy
Thanks for all the help! Here is what my car looks like as of now. I added some spacers and aerosync bumper. Needing some smaller tires tho for sure. Specs are 18x11 -13 and 18x9.5 -3. Im gonna do -18 rear and -13 front when i get my new tires. Rear is maxxed out
Old Jan 16, 2012 | 05:22 PM
  #18672
350z_Boi's Avatar
350z_Boi
damn havent been on here for a WHILE!!! lol but anyways havent got the time to take my car to the shop and get some custom fab work done.. it should be done after im back on my vacay in march but heres a teaser pick of it...19x12 200mm lip!!!!!!!!!! hate it or love it....
Old Jan 16, 2012 | 05:32 PM
  #18673
hyuk28719's Avatar
hyuk28719
^ love it.
in for the pics!
Old Jan 16, 2012 | 06:16 PM
  #18674
Max-G's Avatar
Max-G
i am of the tuck persuasion
Old Jan 16, 2012 | 07:11 PM
  #18675
kemps's Avatar
kemps
Looks great Max, more pics.
Old Jan 16, 2012 | 10:16 PM
  #18676
Big_C's Avatar
Big_C
http://www.flickr.com/photos/cmpixels/6713126663/http://www.flickr.com/photos/cmpixels/6713126663/ by http://www.flickr.com/people/cmpixels/, on Flickr
Old Jan 17, 2012 | 12:42 AM
  #18677
350zDreamZ's Avatar
350zDreamZ
Old Jan 17, 2012 | 04:48 AM
  #18678
black_03's Avatar
black_03
Need help! Hit a pot hole yesterday as I tried to avoid busted concrete in roadway. The run is still holding air as of now and this happened mid afternoon. Anyone know of a good reliable wheel repair or would you even trust that? Here's the photo
Old Jan 17, 2012 | 08:16 AM
  #18679
lowandsteezy
Im about to order some new tires. Do you think 235 is too much of a stretch on 11in wheel? Also how are nankangs? i know there cheap but are they decent tire and do they look good stretched?
Old Jan 17, 2012 | 02:57 PM
  #18680
Kirbaaybaayy's Avatar
Kirbaaybaayy
white HR needs more poke
