Aggressive Wheels and Stretched Tires....Welcome
Old Feb 8, 2012 | 09:08 AM
  #18901
phiooz's Avatar
phiooz
Originally Posted by zombieskicks
Yea it might be a bit risky trav but I think it'll work I've also see 12s with a 255 and a little more stretch wouldn't be that intense, I found these 11.5 running 235 , so I'm guessing a 245 on a 12 would look similar to this
stick to 255 on 12. its safer and a nice stretch..
Old Feb 8, 2012 | 11:41 AM
  #18902
zombieskicks's Avatar
zombieskicks
Yea ima see if I can switch the 245 I have for 255 but If I don't I think I'll just go for it , it won't be that much of a difference. The more stretched the better and easier it will be to fit that bad boy in.
It has 275 now but not for long, I'm also waiting for my camber kit
Old Feb 8, 2012 | 11:51 AM
  #18903
phiooz's Avatar
phiooz
make sure you get 255/35 not 40 series... 245 just sounds so risky, but im sure its been done. my 2 cents, throw 255/35 and some negative camber and youre good.
Old Feb 8, 2012 | 11:55 AM
  #18904
phiooz's Avatar
phiooz
okay enough talk..
here's a picture from this weekend with dan and me. BRG reppin at CCM in austin
Old Feb 8, 2012 | 02:09 PM
  #18905
Bmurray350z's Avatar
Bmurray350z
^ Z on the left.. Too much IMO. Just sayin
Old Feb 8, 2012 | 04:15 PM
  #18906
TehkMob's Avatar
TehkMob
Dan, dis you really put a blast pipe on your z bro?? Take it back homie... Not a good look at all bro.
Old Feb 8, 2012 | 04:18 PM
  #18907
TehkMob's Avatar
TehkMob
Not true at all bro... I was running a 11.5 -24 offset with a roll/pull with ease @ only -4 camber... Which is equal to a 10.5 -49 offset... No custom **** but a Eastwood fender roller.
even a hard pull wont fit those... youll have to do some custom body work.
Old Feb 9, 2012 | 05:04 AM
  #18908
Juci's Avatar
Juci
okay enough talk..
Phiooz more pics and tire/wheel specs!
Old Feb 9, 2012 | 07:04 AM
  #18909
GenX350z's Avatar
GenX350z
too bad i couldnt bring the Z out to CCM .. =/
they figured out the problem when i got back. heres a clip of it back up and running.
http://youtu.be/iuCSw_CyVbU
Old Feb 9, 2012 | 07:10 AM
  #18910
phiooz's Avatar
phiooz
oh.. well i ran 11.5 -21 too and only had a pull too but 10.5 -49 is another -15mm .
Old Feb 9, 2012 | 08:45 AM
  #18911
datsunHEAD's Avatar
datsunHEAD
please tell me thats you driving your own car and not a "tech" from the shop?
Old Feb 9, 2012 | 10:02 AM
  #18912
-miltdoggie-'s Avatar
-miltdoggie-
How would you guys feel about stretching a 245 on a 12 width? I'm in a pickle and only have a set of 245/35/19
Its been done... I ran an 800 mile round trip.. tires ares still going.
Old Feb 9, 2012 | 10:24 AM
  #18913
Stance350zee's Avatar
Stance350zee
hummm ... now i need a vote or something lol
Old Feb 9, 2012 | 10:39 AM
  #18914
zombieskicks
You sir have made up my mind Ima go for it! I should have everything set up by next week and then I'll post some pics
  #18915
-miltdoggie-
Old Feb 9, 2012 | 12:33 PM
  #18916
washyourrhands's Avatar
washyourrhands
yes please.
Old Feb 9, 2012 | 04:48 PM
  #18917
TehkMob's Avatar
TehkMob
Basically, there's like 24.7 mm per inch. So mor or less a 10.5 wide neg 49 is equal to a12.5 wide with 0 offset. Or a 11.5 wide neg 23/24
And so on. Don't let the offset intimidate you because the width comes into play more so than the offset.
Example, a 12wide 0 offset is equivalent to a 8 wide neg 98 offset... Neg 98 sound fucn crazy, but in perspective, it's a very easy fit on the rear of a z.
Hope that example helps you out.
Old Feb 9, 2012 | 05:43 PM
  #18918
JaE35z's Avatar
JaE35z
milt that exhaust must take a beating lol
Old Feb 9, 2012 | 08:46 PM
  #18919
phiooz's Avatar
phiooz
yeah i thought that too but then i saw this and got confused. bc close to 25mm = an inch but i dont know what theyre calculating
http://1010tires.com/WheelOffsetCalculator.asp
Old Feb 9, 2012 | 09:14 PM
  #18920
-miltdoggie-
Yeah its all messed up.... lol
