Aggressive Wheels and Stretched Tires....Welcome
Its because ur rear tires are 6% smaller then the stock sizes which should be making the slip indicator go off. i believe the more u can go is 3%. i use willtheyfit.com to get my tire sizes. im just hella pissed cuz the shop i went to told me to get tire sizes that are a little bigger then stock....so now i cant go as low as i wanna go unless i do hella camber. since i daily drive this i dont want hella amount of camber but since i wanna go lower i guess ima just have to.
I took some hella awesome new photos for everyone
I'm still working on fitment, I've got 25mm spacers I can chuck on the rear, maybe a 10mm up front? If so anyone wanna swap for my 30mm spacers?
It looks like it needs to go lower but its already pretty darn low and this is my daily/grocery getter lol, plus the shop I had do the work weren't keen to go any lower.
Pics:
Pics:
Pics:
Pics:
If youre unable to go low enough to comply with the standards then Im sure there are other threads for you..
I didnt say his car was crap, just saying that for the thread its just not up to par. Yes it is low, relatively speaking. Is it flush though? Ill post mine with stock +30s and tell you Im buying -12s next month, would that be ok?
No hard feelings 350ZAustin. The bar is high and has been up there for quite some time. At least you acknowledged the fact you need spacers, now go get em asap!
Standards
But I noticed you lived in Texas you should be able to reach out to someone from swag n bang. Fitment is on another level out there;
Im here to try to learn and people like u guys make me not want to stay on these forums....even though i have already heard that the my350z forums can have their share of dicks. just my 2 cents
Yea it might be a bit risky trav but I think it'll work I've also see 12s with a 255 and a little more stretch wouldn't be that intense, I found these 11.5 running 235 , so I'm guessing a 245 on a 12 would look similar to this
currently i am about to install 20x9.5 +15 and 20x10.5 +15 with 20mm & 25mm spacers but i came across the same exact wheels with step lip and the following specs: 20x10.5 -27/ 20x10.5 -45 (work t1s) what would it take to make these wheels fit and what tires if possible
