Aggressive Wheels and Stretched Tires....Welcome
Old Feb 23, 2012 | 05:59 PM
  #19021
litoflow's Avatar
litoflow
^^Car is gone! and one of the front wheels needs a new outer lip. 19x10-4F & 19x11-16R
Old Feb 23, 2012 | 06:06 PM
  #19022
vex008's Avatar
vex008
how's your girls car coming along?
Old Feb 23, 2012 | 06:14 PM
  #19023
litoflow's Avatar
litoflow
^^coming good broski but she a little afraid of being so low lol..she doesn't want to scrape much ha!
Old Feb 23, 2012 | 10:49 PM
  #19024
braydo25's Avatar
braydo25
Default Fitting 19x11 +15 & 19x9.5+12?
Hey guys, so I'm going to be mounting some 19x11 +15 (rear) and 19x9.5 +12 (front) on my 2003 350z soon. Perhaps I'm just an absolute noob and did not expect these to poke as much as they do, perhaps more research should have been done. But regardless, I'd like to get these to fit.
As of right now the car is all stock, but will have ksport coilovers, camber / toe kit installed and about 1" of drop before the wheels go on.
I'm curious as to the issues I'll run into with running such an aggressive size in the rear? I've mounted the wheels up and there's about 1.2" of poke, or ~30mm from the rear fender to the end of the wheel.
I'll be stretching a 245 tire on the rears, rolling my fenders, but I still don't believe that will be enough to comfortably fit these? Any suggestions?
Pics of test mount:
Old Feb 24, 2012 | 12:42 AM
  #19025
Juci's Avatar
Juci
Put something under wheel(to protect lip)and lower car to ground, then you see what you have to do. Wheel will get some camber and situation is not so bad. I have these same wheels but hyper black.
Old Feb 24, 2012 | 01:05 AM
  #19026
sdZ33's Avatar
sdZ33
put the car on jack stands, now with the wheel mounted like it is, jack up the wheel to where it will sit at the desired ride hieght...If you are going to put a 245 on that rear wheel, you will have a very good ammount of stretch...
What wheels are they btw?
Old Feb 24, 2012 | 02:23 AM
  #19027
acke15's Avatar
acke15
Let's see, you mess up the geometry of the suspension, and expect the wheels to tuck when it's jacked up?!? I run a 18x10.5 + 15 all around. And when I was lowered, I tucked all 4 corners. I was running 275/35/18 all around as well. The wheels will fit, you'll just need some negative camber. Oh and have fun with strectching that rear tire.
Old Feb 24, 2012 | 03:04 AM
  #19028
terrasmak's Avatar
Mount a 255/35 up front and a 285/35 on the back, run the rear camber on the high side of OEM specs -2.1 and set the front camber to -1.8 and your good to go. No need to run a lame *** 245 on those rear wheels.
Old Feb 24, 2012 | 08:30 AM
  #19029
rubix_cube12's Avatar
rubix_cube12
Anybody done a bridgestone potenza 255/30/19 on an 11 in?
Old Feb 24, 2012 | 09:44 AM
  #19030
Waiz's Avatar
Waiz
Pics of test mount:
Merged with the correct thread to ask this question
Old Feb 24, 2012 | 10:19 AM
  #19031
datsunHEAD's Avatar
datsunHEAD
lower the car just like that with no tire,guarantee it will tuck
Old Feb 24, 2012 | 01:05 PM
  #19032
DeeSan's Avatar
DeeSan
dude you're wheels will tuck like oem wheels LOL
Old Feb 24, 2012 | 01:28 PM
  #19033
-miltdoggie-'s Avatar
-miltdoggie-
Some even ground...
Old Feb 24, 2012 | 01:50 PM
  #19034
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Is there any exhaust that recesses or sits higher than OEM? Basically, lowered car friendly.
Old Feb 24, 2012 | 07:11 PM
  #19035
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
Custom bent straight pipe )
On my hks I cut out the mufflers under the middle of the car and put a straight pipe there so it won't hit the ground as much
Old Feb 25, 2012 | 08:59 AM
  #19036
zombieskicks's Avatar
zombieskicks
How was the sound quality? The Hks has a nice deep tone.
Old Feb 25, 2012 | 09:06 AM
  #19037
Royal_T's Avatar
Royal_T
Missing my car right now since it is in pieces and finishing up my build.. So I decided to post up a old pic.. Very soon will be back stronger then ever..
Old Feb 25, 2012 | 09:54 AM
  #19038
Wicked_Limitz's Avatar
Wicked_Limitz
^ one of the best Z's ever...
Old Feb 25, 2012 | 09:58 AM
  #19039
SQBassHead's Avatar
SQBassHead
Question
Originally Posted by -miltdoggie-
Does anybody know the specs on both of these grey cars?
Thank you
Old Feb 26, 2012 | 08:56 AM
  #19040
stein350z's Avatar
stein350z
also 4 my POV
