Is it possible to squeeze a 16x7.5 rim on Z33 base model ?
Old Dec 2, 2007 | 12:29 PM
ceasars chariot's Avatar
ceasars chariot
Default Is it possible to squeeze a 16x7.5 rim on Z33 base model ?
Thanks in advance, im going to continue to search and see if I can get a definite yes or no. I know very little about the 350z. I believe the base model has smaller calipers and rotors than the enthusiasts, and track models that come with brembos.
- What I have is SSR Competitions Type C in 16 x 7.5. I got them from tirerack several years ago. This past weekend I over reved my VQ30DE in a 97Nissan Maxima and the engines finished. (R.I.P. 173,000 miles 1997-2007)
- Im wanting to move on to a 350Z, and wanted to find out if a 16 x 7.5 would squeeze over the rotors and calipers. This is probably not that popular of a topic since most people go with larger rims. But for me I do quite a bit of drag racing and already have the SSR Type C's and drag radials.
At 11 lbs each and the 16 inch rim, this smaller size would help against rotational inertia and upsprung weight.
Thanks again, for anyone who takes the time to share a bit on this topic.
Old Dec 2, 2007 | 12:30 PM
Zilvia's Avatar
Zilvia
it depends if the lug pattern is 5x114.3
but i do think that it will more that likely rub the calipers
it also depends on the off set as well......
Old Dec 2, 2007 | 12:36 PM
ceasars chariot
these are 5 x114.3, some of the maxima guys upgrade to the 350z stock rims. Guessing im thinking they are 40mm offset will have to check.
Beau's Avatar
Beau
A friend of mine has 16x8's with a 0 offset and it wouldn't fit on the front of my car. The wheel contacted the control arm. Other than that, 16's will be awfully small on a Z.
Old Dec 2, 2007 | 01:02 PM
ceasars chariot
measured correctly just have tape measure sitting in photo. yeah i agree, the idea would be to use on the rear for drag racing days only. it may be a long shot, just thinking ahead to use every trick in the book to get a 350Z into the 12.9 area all motor. If by some chance this would work just didnt want to overlook it.
Question: Does the base model have smaller rotors and calipers so to speak ?
14 inches and a hair or two
15 1/2 inch
Will check on offset.
Old Dec 2, 2007 | 03:41 PM
Its possible yes. Look at the diameter of the donut wheel.
Old Dec 2, 2007 | 04:05 PM
ceasars chariot
dave are you refering to the base model 350Z donut or spare tire diameter ? anyone have measurements on that?
Old Dec 2, 2007 | 06:02 PM
DustinZ33's Avatar
DustinZ33
why would you want to put a smaller wheel than it comes with? that just plain retarded. I'm sorry I can't answer your question. but why?
Old Dec 2, 2007 | 06:12 PM
Zilvia's Avatar
Zilvia
yea i have been pondering this too.... the 17s already look to small
16 will just be bad
Old Dec 2, 2007 | 07:08 PM
ceasars chariot
ok guys here we go.
im asking because if this works it will knock several tenths off a 1/4 mile run. take the old maxima of mine for example. the stock wheel and tire combo weighed in at 40 lbs each. I put these rims on with street tires replacing the stock maxima ones. I dropped 8 lbs per wheel and tire, overall (all 4) 32 lbs.
For every 1 lb you remove from unsprung weight it has the effect of removing 10 lbs off the chassis. (rough figure to use in calculation)
32 x 10 = 320 lbs
(another rough calculation) for every 100 lbs of weight you reduce off a car, you cut off a .1 off ya e.t.
Took the car out to the drag strip and low and behold i was .3 faster. so i took this formula, did the calculations and then backed it up on the dragstrip.
And this was with the same size rim. In the 350z case a 16 inch would also have a positive effect on rotational inertia which is also a good thing, a smaller wheel will also change the gearing so to speak.
so its not for looks, im all about some 18 inch volk te37s when the time comes aye. but im interested in this information for drag racing.
given the Z33 base model wheel and tire is 40lbs per combo (could be more) if by chance these rims fit, i will have knocked a .3 off the 1/4 mile time at least and all i had to do was change the rims.
hope this helps in giving you an idea about why im asking, but cosmetically I agree, it sure would look nasty ! lol !
Old Dec 2, 2007 | 07:10 PM
Zilvia's Avatar
Zilvia
is .3 off really even worth it......
Kwame's Avatar
Kwame
The OP has already stated this will be "for drag racing days only."
Old Dec 2, 2007 | 07:12 PM
Justin07Z's Avatar
Justin07Z
I can't answer your question, but that would be cool as heck to fit those ultra light SSR Comps on at least the rear for a track run. Comparing the boat anchor 26 lb stock 18's to those 12lb 16's would make a tremendous difference in acceleration, at least 3/10's.
Zilvia's Avatar
Zilvia
but still.....
why waste the time....thats why i never understood drag racing....so pointless
but hope if works out for you then. too bad none of your friends have Zs, you could just test fit it on there
ceasars chariot
dustin your from houma ? i used to race over at No Problem Raceway (belle rose, la) all the time. You ever get over that way ?
Old Dec 2, 2007 | 07:13 PM
Justin07Z's Avatar
Justin07Z
....if you have to ask...you must
Old Dec 2, 2007 | 07:14 PM
Zilvia's Avatar
Zilvia
what must be crazy.....nope
Old Dec 2, 2007 | 07:15 PM
mcarlomagno's Avatar
mcarlomagno
last time i checked the idea of racing is to have the lowest time possible in your setup.
ceasars chariot
but of course....> .3 is huge especially if its a free modification.
Old Dec 2, 2007 | 07:16 PM
Zilvia's Avatar
Zilvia
hey im just saying......
