tire pressure monitors reset?
Hey guys I put some 19" wheels on the car and moved the tire presssure monitors in there but they do not work.
Do i need to get them reprogrammed or what? They do not work...I went to the dealer and they said they could fix it but its $45 a tire, thats a SHITLOOAD..haha any other suggestions
-Mo
-Mo
well the dealership said soemtimes they can loose the programming with interference. I dont know.
Is the dealership the only place that can do that, because they are charing a **** load
-Mo
-Mo
Yes, for the most part the dealer is the only one who can reprogram them. Unless you find somebody else with the Consult II system.
They shouldn't charge much more than $50 as it doesn't take that long to do the procedure.
Originally Posted by MrWatchDawg
The dealer said its ****ing $45 a tire...thats insane. close to $200 to get it programmed.
I dont understand why that much
-Mo
-Mo
Don't attempt to understand why someone is charging you "that much." The choice is yours as a consumer to take it elsewhere.
all the dealer does...is take the consult II and hold a button against where the tps is inside the tire for about 20 seconds each tire and he wants to charge your 180$ for that? thats insane...last time i got them reprogrammed they did it for free as well as putting air in my tires.
