Rear tires... / \
Old Dec 10, 2007 | 02:32 PM
JM1521's Avatar
JM1521
Default Rear tires... / \
It appears that the rear tires on my ZR (if looking from directly behind the vehicle) look like they're off-angle / \
It seems that this is causing the inside of the tires to wear faster than the outside. I bought the ZR used with about 19k miles and it looks as if it may have been lowered. How would I be able to tell if it has been lowered and if it was, could this be the problem or is there an adjustment and this is a normal/common problem? (.....or did I pull a dukes of hazzard a little too hard) j/k
(And for the "go do a search" people... I searched and searched, there is nothing regarding the rear tires being off, they're all about the front tires and the tire feathering issues.)
Any help is appreciated.
Thanks
Old Dec 10, 2007 | 02:35 PM
918 Z's Avatar
918 Z
you are suffering from rear negative camber. some camber arms will allow you to adjust them and make the degree 0. do a search on camber
Old Dec 10, 2007 | 02:36 PM
iStan's Avatar
iStan
ZR
Check the springs and describe what they look like and see if there are any distinguishing marks on them. Your ZR sounds like it has been dropped.
Old Dec 10, 2007 | 02:41 PM
JasonZ-YA's Avatar
JasonZ-YA
You need to buy camber arms and more adjustable toe bolts in order to get your alignment back to spec. it does sound like your car is lowered, just not done properly.........need those parts.
-j
Old Dec 10, 2007 | 02:42 PM
usmanasif's Avatar
usmanasif
The Z comes with a slight negative camber in the rear from factory (I had mine checked when I bought it) but it is nowhere near high enough to be visually identifiable. I agree with the posters above; the previous owner may have dropped it too low. Anything greater than 1" or so will need a camber kit.
Old Dec 10, 2007 | 03:15 PM
JM1521's Avatar
JM1521
Thanks for your help everyone, I'm going to look into it as soon as I get home.
Old Dec 10, 2007 | 03:32 PM
terrasmak's Avatar
Factory camber specs for the rear are -1.5 to -2.1 (off the top of my head) and easily noticable if you look at it. Rear camber doesnt change much between alignments, but F&R toe seems to. Toe eats tires faster than camber.
Old Dec 10, 2007 | 05:27 PM
shaneotool's Avatar
shaneotool
Your car may very well be at stock height. You can easily see the negative camber on a stock Z. Go to a nissan dealership and look at the z's on the lot and see if they look about the same.
Old Dec 10, 2007 | 05:46 PM
abeklipse's Avatar
abeklipse
Why is it that most 2003 Z's with stock suspensions have / \ negative camber in the rear?
Old Dec 10, 2007 | 06:52 PM
z350boy's Avatar
z350boy
Thanks
I need additional information to assist you such as:
(1) Has the car been lowered??
You need to confirm if your Z has been lowered. This will determine your course of action.
(2) Do you have aftermarket wheels??
This is important because if you do as stated above you may need to have elongated toe bolts and radius arms in the rear such as SPL ( the standard in the Z world). Adjustable a-arms would be useful up front. These will allow you camber to be adjusted in order to retain stock specs.
(3) What is the state of your suspension??
Have dealer check suspension to see if it is ok. You could have weak springs or bad shocks. Have end links checked.
Just a few suggestions to help you along the way.
Old Dec 10, 2007 | 07:55 PM
What you are looking at is static alignment. Often deceiving. What you are interested in is dynamic alignment: alignment when the car is moving.
I might be able to tell you more about the alignment if you posted a photos of the tires.
Old Dec 10, 2007 | 08:05 PM
rkd350z's Avatar
rkd350z
Neg camber= better handling when tuned properly
Old Dec 10, 2007 | 09:24 PM
Chebosto's Avatar
Chebosto
@_@ - OMG ur car is about to explode.. purchase toyota camry. so you can have wheels that are | |
\o/ -woot
Old Dec 11, 2007 | 06:44 AM
JM1521's Avatar
JM1521
Just found out the Z has been lowered 1.2 inches. It has the Tanabe NF210 set-up with stock rims. I was wondering why I couldn't even get my floor jack under it!
Is there something I am able to adjust or does it have to be professionally done?
Old Dec 11, 2007 | 08:19 AM
sfarrah's Avatar
sfarrah
You should be able to install the arms yourself but you'll need to have it aligned by a shop.
Old Dec 11, 2007 | 08:46 AM
jinsei888's Avatar
jinsei888
i dunno about all the other advice, but just take your car to an alignment shop and they will tell you if your alignment is off or not and if it is uncureably off, then you might be correct to assume it's lowered
obviously posting pictures would give us all a better idea of whether it's lowered or not
keep in mind, our Z's OEM spec DO have neg camber all around, and it's normal, its the toe and caster that you have to concern yourself about in terms of OEM spec tire wear issues
Old Dec 11, 2007 | 12:43 PM
bbs350z's Avatar
bbs350z
its pretty much gonna always be that height. if you wanna adjust them youd need coilovers.
Old Dec 11, 2007 | 02:26 PM
Calvin@CRG's Avatar
Calvin@CRG
Temporary Disablement - Billing
negative camber ftw say bye bye to tires =) im on my 5th set of tires and ive only owned my car for 4.5months
Old Dec 11, 2007 | 11:01 PM
Chebosto's Avatar
Chebosto
deliberate burn outs dont count..
Old Dec 11, 2007 | 11:11 PM
black06z's Avatar
black06z
5 set of tires on a 4.5 month Z? That's crazy.
Im pretty sure the OP is gonna need a camber/toe kit, especially on the ZR which is already lower than the coupe(stock), and heavier. The NF is like a 1.2" drop, and he probably got close to 2" with the ZR. THmotorsports has a special on the SPC camber/toe kits. Go check out the vendor thread.
I wanna see some pics of that big drop.
