Where to buy wheel spacers?
Old Dec 13, 2007 | 02:22 PM
redlude97's Avatar
redlude97
Originally Posted by Andy@Performance
That's funny cause I just put H&R 5mm spacers on my car and didn't notice any hub centric rings. The cool thing about the KICS spacers are that they're easy to install cause the studs are already built in.
5mm spacers don't need them because the hub extends past the spacer. Larger spacers do like these ones. Eibachs have built in studs as well
Old Dec 13, 2007 | 02:24 PM
Sean's Avatar
Sean
if your stud gets screwed up later you will have to change the spacer, the traditional type isn't rocket science.
Old Dec 13, 2007 | 02:33 PM
redlude97's Avatar
redlude97
Why? The studs press out just like the OEM ones, you would just have to get a new stud with the correct length and threads
Old Dec 13, 2007 | 03:47 PM
SniperHunter's Avatar
SniperHunter
Andy: Yep. Have that link saved already. =)
Originally Posted by dutchboy350Z
I hope you guys price match. $140 for a pair of Project Kics? They can easily be found anywhere else for $30 less.
Where at?
Old Dec 13, 2007 | 05:34 PM
RED RIDER's Avatar
RED RIDER
Bought ichiba 15mm spacers and they are hubcentric...2 day delivered from cali to Austin, Texas was 119.50. They came with new extended studs...I actually have a brand new pair of 10mm that were too thin..extra 5mm and my wheels finally cleared my stoptechs...'course now i am getting the fenders rolled this sat am...
Old Dec 13, 2007 | 08:16 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Where at?
http://www.evasivemotorsports.com/me...s_Wheel_Spacer
make sure you get the hubcentric rings too.
http://www.evasivemotorsports.com/me...e=KICS_HUBRING
Old Dec 13, 2007 | 08:35 PM
doree610's Avatar
doree610
so it seems most spacers require hubcentric rings? i just wanna find the most convenient 10mm spacer. nothing that requires additional parts, but that comes with everything. eibach a good choice?
Old Dec 13, 2007 | 08:49 PM
SniperHunter
Awesome, thanks for the link. May I ask what the importance of the rings is? =)
Old Dec 13, 2007 | 09:46 PM
dutchboy350Z
Finally some go
Without hubcentrics rings you'll get wheel vibrations at higher speeds. Vibration = annoying and possible damage to wheels studs.
Old Dec 13, 2007 | 11:33 PM
Triple8Sol's Avatar
Triple8Sol
Project KICS is the only one I know of that requires the purchase of an additional hubcentric ring that fits betwen the hub and the inner bore of the spacers. The center bore of others I've looked at from H&R, Eibach, and Ichiba are made to be hubcentric, so that no additional rings are needed. Saves you quite a bit.
Old Dec 17, 2007 | 05:28 AM
azula's Avatar
azula
Originally Posted by drift_projekt_Z
i have the ichibas..slight wobble up front. they are hubcentric
slight wobble? did you install them? is anyone else experiencing this? i want to get spacers but i don't want wobble.
Old Dec 17, 2007 | 07:22 AM
jOeL350z's Avatar
jOeL350z
with all discussion here, who makes the best spacers that does not have any wobble?
Old Dec 17, 2007 | 09:51 AM
redlude97's Avatar
redlude97
Depends on what type of spacer you are looking for. No spacer should wobble anyways, likely its install error
Obadabot
Jun 18, 2023 11:31 PM
