suggestions: 18x10.5 + with low offsets (+12 or so)
Old Dec 27, 2007 | 07:54 PM
fairl80z's Avatar
fairl80z
Originally Posted by WPPJR30
Those are hott!
More of same wheels on same car advan RS 18X10 +15 all corners
Attached Thumbnails suggestions: 18x10.5 + with low offsets (+12 or so)-alex1.jpg
Old Dec 27, 2007 | 07:56 PM
fairl80z's Avatar
fairl80z
two more.
Click on pix to show larger size
Attached Thumbnails suggestions: 18x10.5 + with low offsets (+12 or so)-alex2.jpg
Old Dec 27, 2007 | 08:02 PM
fairl80z's Avatar
fairl80z
More
Attached Thumbnails suggestions: 18x10.5 + with low offsets (+12 or so)-alex4.jpg
Old Dec 27, 2007 | 10:40 PM
JETPILOT's Avatar
JETPILOT
Originally Posted by str8dum1
ya thats the problem then. the rears on that red car looks waay more concave then yours. I thought the offset moved the face of the wheel. less offset meant more space between the lip and the mounting bolts. But you say that Advan keeps the face in the same spot and just builds up material (10mm in the instance) behind the face?
FWIW, the red Z only had to roll his rear fenders to fit those 10.5 +15 front and back.
Interesting.
Yes... the mounting pad thickness changes. The face doesn not change.
The red car likely has 275 tires on the back and not 295 tires. I have 295.
The wheel size is 10. Not 10.5
The poster above states these wheels are 18. And by the look of it his tires are 275.
JET
Old Dec 28, 2007 | 12:53 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Actually, the face does change. You can compare a TE37 19x10.5 +22 and a 19x10.5 +12 and you can see the face has a bigger dish and is slightly more concave. The pad thickness doesn't have anything to do with offset. You can still have a low offset wheel but in a high pad version, again, just like a TE37 19x10.5 +12; low offset wheel but has high pad clearance.
Old Dec 28, 2007 | 01:30 PM
Kwame's Avatar
Kwame
19 x 10.5 +12
Old Dec 28, 2007 | 01:39 PM
Andy@Performance
Performance Nissan
Originally Posted by kwame@z1
19 x 10.5 +12
Dude, hurry up and put them on!
Old Dec 28, 2007 | 01:42 PM
Zquicksilver's Avatar
Zquicksilver
But not for all rims... I know my SF winnings spoke cross-section is similar front and rear, but the mounting "pad" or a cross-section of the rear casting pad is much thicker. Yes, its a two-piece and they play around with the forged spinning or ring "lip" depths too. And as you stated, there is also a high/mid/low pad version of the spoke casting.
Its amazing how many combinations there are just for my wheel type, a lot of R&D and money spent on manufacturing!
I want to run 305/30/19 PS2s in the spring. And I actually wish I had a +40 offset in the rear...
My 350 is dropped and the camber is around -1', and my wheels still stick out... lol.
Old Dec 28, 2007 | 01:46 PM
Kwame's Avatar
Kwame
You know I want to... I still have yet to pick up those things I wanted from you. I'll hit you up via e-mail since I'm never on AIM.
Old Dec 28, 2007 | 02:00 PM
JETPILOT's Avatar
JETPILOT
Check my other posts. I was refering to the ADVAN RS. The face does not change.
JET
Old Dec 28, 2007 | 02:09 PM
Andy@Performance
Performance Nissan
Yup, you're right. There are so many variables when it comes to wheel fitment, wheel "A" can have high pad, low offset, wide width while wheel "B" can have low offset but no high pad option. It all varies with the design of the wheel itself as well. It's difficult to compare your Winning's in this scenario though as they're a 2 piece wheel. If you compare monoblock to monoblock, it would make more sense.
Old Dec 28, 2007 | 02:14 PM
Andy@Performance
Performance Nissan
JET
I didn't see your reference specifically about the ADVAN RS. On ADVAN wheels, you're right, they only offer 2 different face type, regular and GTR. The GTR face will have concavity where as in the regular will not so the lower offset wheel will not have anymore concavity than the higher offset wheel if they both have the GTR face. You're right, Larry!
Old Dec 28, 2007 | 02:15 PM
Andy@Performance
Performance Nissan
Hit me up.
Old Jan 1, 2008 | 02:51 PM
str8dum1's Avatar
str8dum1
Perfect, thats the kinda of info I was looking for. Which of those face types clear OEM brembos?
350Z_Al
Oct 29, 2020 07:44 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
